trans help, 901 racing tranny |
porschechuck |
Apr 12 2007, 09:53 PM
Newbie Group: Members Posts: 9 Joined: 20-March 04 From: Louisville,KY Member No.: 1,824 |
Hi all,
Raced at road Atlanta last month came 4th against H.O. 2.2 sixes with my 2.0 4cyl. But trans issues, running a stock '73 box. On the back straight 4th pulled barely, and 5th was just blaaaah no increase in revs. I need help! We've tigged a diff to create a locker, Mid ohio teener club thanks, but what gears and where can i buy them. thanks for any thoughts and recommendations |
DanT |
Apr 15 2007, 10:17 AM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
Greg, are you using a stock ring and pinion with stock final drive...?
I have been considering a A,F,Ka,R,Z box for my 2056 build. Anyone out there done this one? Ka is a stock ZD flipped R is a stock V flipped Z is a stock N flipped. this way I would not need to buy any gear sets...just use what is already in the tranny. New motor should be good for about 6K rpms. maybe 6200. (IMG:style_emoticons/default/smile.gif) with this box there would only be about a .4 gear ratio drop from 2nd to 3rd and 3rd to 4th. here is a sheet with the stock vs custom gearing Attached File(s) gear_ratios_from_stock_gears.txt ( 618bytes ) Number of downloads: 141 |
stownsen914 |
Apr 17 2007, 09:44 AM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
QUOTE Ka is a stock ZD flipped R is a stock V flipped Z is a stock N flipped. There's only one problem with flipping a stock V 4th/5th ratio to get an R ... you've now got an R 3rd gearset (not 4th). Flipping the ZD and N gearsets does work as you suggest. |
Aaron Cox |
Apr 17 2007, 11:53 AM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
QUOTE Ka is a stock ZD flipped R is a stock V flipped Z is a stock N flipped. There's only one problem with flipping a stock V 4th/5th ratio to get an R ... you've now got an R 3rd gearset (not 4th). Flipping the ZD and N gearsets does work as you suggest. (IMG:style_emoticons/default/agree.gif) you can flip 3rds to 5th's and 2nd gears to 4th gears.... no intermingling allowed. |
Lo-Fi Version | Time is now: 31st May 2024 - 06:17 PM |
