> Is there any way to tell if my L-jet brain is dead without swapping it
jd74914
post Apr 18 2007, 10:47 AM
Its alive
Hi guys, heres the problem.
A few months ago my car was running great. I had just rebuilt the engine and put everything back on. After fixing some grounding problems it ran perfectly.
Then, I went on vacation, came back and did some welding and forgot to unhook the brain when I unhooked the battery. After this the car wouldn't start. It wasn't getting any fuel. The coil also got really warm at one point, so I replaced it with another known good, new one I had. Now with the new coil, and a new fuel pump (I also had a known good pump) put in, the car still won't start.
It turns over fine, but it won't even run for a second on the cold start valve (IMG:style_emoticons/default/sad.gif)
Is there a problem with the brain or is there something else I should look for? I can't think of any other things to go bad. (IMG:style_emoticons/default/idea.gif) I'm pretty sure the points are good.
Its a 74 L-Jet BTW
SLITS
post Apr 18 2007, 03:18 PM
"This Utah shit is HARSH!"
The single yellow wire to your starter is from your key switch which delivers the 12VDC to the solenoid in the "start" position.
If the starter continues to run, you've got problems elsewhere (Ignition switch, relay board connections, starter solenoid or incorrect wiring.
jd74914   Is there any way to tell if my L-jet brain is dead without swapping it   Apr 18 2007, 10:47 AM
jimkelly   guess you gotta check for spark, is fuel pump comi...   Apr 18 2007, 11:11 AM
jd74914   The pump isn't coming on at all. Thats what ha...   Apr 18 2007, 11:39 AM
r_towle   remove the big ass Air flow meter valve from the l...   Apr 18 2007, 12:14 PM
jd74914   Ok, Thanks for that thought Rich. I'll try pr...   Apr 18 2007, 02:10 PM
Dave_Darling   The pump should also run when the starter is crank...   Apr 18 2007, 02:50 PM
jd74914   The pump should also run when the starter is cran...   Apr 18 2007, 02:58 PM
SLITS   The single yellow wire to your starter is from you...   Apr 18 2007, 03:18 PM
ChrisNPDrider   I just went through this with D-jet and the soluti...   Apr 18 2007, 03:32 PM
bd1308   that yellow wire goes to the bottom RIGHT pin on t...   Apr 18 2007, 03:36 PM
jd74914   Bottom right is i'm looking from the battery t...   Apr 18 2007, 03:41 PM
bd1308   trunk   Apr 18 2007, 04:04 PM
jd74914   mine was always plugged into the left thanks   Apr 18 2007, 04:06 PM
computers4kids   mine was always plugged into the left thanks Mi...   Apr 18 2007, 07:55 PM
bd1308   if you stood behind the trunk and was looking at t...   Apr 18 2007, 08:08 PM
computers4kids   if you stood behind the trunk and was looking at ...   Apr 18 2007, 08:12 PM
bd1308   alright here's what you need to do: After the...   Apr 18 2007, 08:29 PM
ClayPerrine   The Ignition turns the IGN relay on the relay bo...   Apr 18 2007, 09:53 PM
jd74914   I think I have heard the clicks . . . I'll che...   Apr 18 2007, 09:50 PM
- Lo-Fi Version Time is now: 4th July 2025 - 11:17 AM
