> Is there any way to tell if my L-jet brain is dead without swapping it
jd74914
post Apr 18 2007, 10:47 AM
Its alive
Hi guys, heres the problem.
A few months ago my car was running great. I had just rebuilt the engine and put everything back on. After fixing some grounding problems it ran perfectly.
Then, I went on vacation, came back and did some welding and forgot to unhook the brain when I unhooked the battery. After this the car wouldn't start. It wasn't getting any fuel. The coil also got really warm at one point, so I replaced it with another known good, new one I had. Now with the new coil, and a new fuel pump (I also had a known good pump) put in, the car still won't start.
It turns over fine, but it won't even run for a second on the cold start valve (IMG:style_emoticons/default/sad.gif)
Is there a problem with the brain or is there something else I should look for? I can't think of any other things to go bad. (IMG:style_emoticons/default/idea.gif) I'm pretty sure the points are good.
Its a 74 L-Jet BTW
bd1308
post Apr 18 2007, 08:08 PM
Sir Post-a-lot
if you stood behind the trunk and was looking at that pin, is it not the bottom right?
thanks
jd74914   Is there any way to tell if my L-jet brain is dead without swapping it   Apr 18 2007, 10:47 AM
jimkelly   guess you gotta check for spark, is fuel pump comi...   Apr 18 2007, 11:11 AM
jd74914   The pump isn't coming on at all. Thats what ha...   Apr 18 2007, 11:39 AM
r_towle   remove the big ass Air flow meter valve from the l...   Apr 18 2007, 12:14 PM
jd74914   Ok, Thanks for that thought Rich. I'll try pr...   Apr 18 2007, 02:10 PM
Dave_Darling   The pump should also run when the starter is crank...   Apr 18 2007, 02:50 PM
jd74914   The pump should also run when the starter is cran...   Apr 18 2007, 02:58 PM
SLITS   The single yellow wire to your starter is from you...   Apr 18 2007, 03:18 PM
ChrisNPDrider   I just went through this with D-jet and the soluti...   Apr 18 2007, 03:32 PM
bd1308   that yellow wire goes to the bottom RIGHT pin on t...   Apr 18 2007, 03:36 PM
jd74914   Bottom right is i'm looking from the battery t...   Apr 18 2007, 03:41 PM
bd1308   trunk   Apr 18 2007, 04:04 PM
jd74914   mine was always plugged into the left thanks   Apr 18 2007, 04:06 PM
computers4kids   mine was always plugged into the left thanks Mi...   Apr 18 2007, 07:55 PM
bd1308   if you stood behind the trunk and was looking at t...   Apr 18 2007, 08:08 PM
computers4kids   if you stood behind the trunk and was looking at ...   Apr 18 2007, 08:12 PM
bd1308   alright here's what you need to do: After the...   Apr 18 2007, 08:29 PM
ClayPerrine   The Ignition turns the IGN relay on the relay bo...   Apr 18 2007, 09:53 PM
jd74914   I think I have heard the clicks . . . I'll che...   Apr 18 2007, 09:50 PM
- Lo-Fi Version Time is now: 4th July 2025 - 11:21 AM
