> front camber, reducing negative camber
tomburdge
post Apr 18 2007, 05:19 PM
I am trying to reduce the front negative camber on my SCCA F prod car.
Currently the stock camber plate will only allow about 1-1/2 to 1-3/4 neg. I want to get closer to 1 deg neg.
I looked at the Weltmiester billet alum camber plates and thought about reversing them side to side to create more positive or in my case less negative camber.
Anybody have any ideas or solutions to my dilema.Any and all responses are greatly appreciated.
r_towle
post Apr 18 2007, 11:26 PM
Custom Member
take out the strut and the top bearing plate.
Take a dremel and grind the three holes oval towards the outside of the fender.
You may have to grind away either the edge of the large hole, or possibly notch the top plate just a bit if you need alot more movement.
Put it all back together, now you can get a bit more adjustment.
Rich
- Lo-Fi Version Time is now: 2nd April 2026 - 12:46 PM
