Push rod tube seal replacement |
whitey |
Apr 20 2007, 11:58 AM
Member Group: Members Posts: 146 Joined: 8-February 07 From: Coto de Caza Member No.: 7,508 |
I want to replace my push rod tube seals without removing the heads. Do I twist and pull the tubes with pliers? Also, my engine is out of the car and I'm reinstalling the injection, re-sealing and doing a engine clean up...My compression was good at 130 psi with no smoking. I don't really want to pull the heads and cylinders but do you see any real advantage to doing this, (ie. honing the cylinders and removing carbon).
Thanks for your response |
SGB |
Apr 20 2007, 03:52 PM
just visiting Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
left out step 3 B, remove PR tube retaining wire.
Also, make sure PRs go back into same hole with the same end at lifter |
Lo-Fi Version | Time is now: 8th June 2024 - 09:17 AM |
