favorite engine drop method, what's yours? |
mightyohm |
Nov 21 2003, 11:02 PM
Advanced Member Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest |
Last time I helped drop a 914 engine, we used the Pelican method of lowering the car almost to the ground and letting the motor plop out onto a furniture dolly. I don't know that I like this method because it really requires 2 jacks and there is no obvious way to get the engine back in when you're done, since you used gravity to help get it out.
I would like to raise and support the car, then lower the engine on my floorjack. But there is obviously going to be a balance problem. I've also heard some people use threaded rods to slowly lower everything but this sounds like too much trouble. So what's the best way? |
URY914 |
Nov 23 2003, 07:44 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,091 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
1) I pick up the back of the car with one hand
2) Loosen the two bolts that I have holding the engine in with the other hand. 3) Shake it real good. 4) Engine falls on foot. 5) Kick the engine out from under car. Paul (IMG:style_emoticons/default/smilie_pokal.gif) |
Lo-Fi Version | Time is now: 12th June 2024 - 08:18 PM |
