Need Help On 1.8 Debate, Motor Change 74/75 |
914runnow |
Apr 21 2007, 08:48 AM
Member Group: Members Posts: 340 Joined: 19-April 04 From: Modesto California Member No.: 1,948 Region Association: None |
Hi all..
Sorry I have disappeared for a while.. I am bizy on my 75 1.8 resto... Had an engine fire..(A definite challenge)!! Which brings me to this topic... I am getting parts from a couple with a rust bucket 75 1.8.. Their Build date is 10/74 Vin #1728 Mine VIN is 2277 10/74...They made 11368 cars 2.0 and 1.8 in 75 .. Works out to be 947 cars a month or so.. Both of our cars were real close # wise.. Actually seems their car should have been 9th month of 74.. By crunching the #'s.. If it was 10th month.. Theirs would have to be one of the first off of the line.. Oh and their EC Block #039166 is good for 75 build too!! So here is my dilemma.. The parts they sent are the 74 '6' pin harness injection system and brain for a 74.. 75 had the 7 pin and a different brain to go with that.. Plus a host of other things to go along with the 75 model 1.8.. Soooo does any one else have a early 75 1.8 to shed light on this.. As to when they (Porsche) changed over to the 7 pin system?? OR ANYONE> have the info that could tell this?? (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/sad.gif) Thanx Rx |
Pat Garvey |
Apr 21 2007, 08:58 PM
Do I or don't I...........? Group: Members Posts: 5,899 Joined: 24-March 06 From: SE PA, near Philly Member No.: 5,765 Region Association: North East States |
Hi all.. Sorry I have disappeared for a while.. I am bizy on my 75 1.8 resto... Had an engine fire..(A definite challenge)!! Which brings me to this topic... I am getting parts from a couple with a rust bucket 75 1.8.. Their Build date is 10/74 Vin #1728 Mine VIN is 2277 10/74...They made 11368 cars 2.0 and 1.8 in 75 .. Works out to be 947 cars a month or so.. Both of our cars were real close # wise.. Actually seems their car should have been 9th month of 74.. By crunching the #'s.. If it was 10th month.. Theirs would have to be one of the first off of the line.. Oh and their EC Block #039166 is good for 75 build too!! So here is my dilemma.. The parts they sent are the 74 '6' pin harness injection system and brain for a 74.. 75 had the 7 pin and a different brain to go with that.. Plus a host of other things to go along with the 75 model 1.8.. Soooo does any one else have a early 75 1.8 to shed light on this.. As to when they (Porsche) changed over to the 7 pin system?? OR ANYONE> have the info that could tell this?? (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/sad.gif) Thanx Rx I think we need Jeff Bowlsby here. If he doesn't respond on this notice, try bowlsby@aol.com |
ClayPerrine |
Apr 21 2007, 09:06 PM
Life's been good to me so far..... Group: Admin Posts: 15,508 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I think we need Jeff Bowlsby here. If he doesn't respond on this notice, try bowlsby@aol.com Pat.. Jeff really doesn't do L-Jet. That being said, I can answer that question. Porsche/VW used up the leftover parts from the previous years production before switching to the newer ones. So it is possible to have a 74 L-jet system on a 75 model year car. I have seen a 73 2.0 that had a tail shifter in it, and it came from the factory that way. I have also seen a 73 with early window mechanisms and no door beams. There is not much functional differences between the 2 systems. If you really want to be absolutely correct, I have 7 pin air flow meters, harnesses, and brains. I will swap straight up for the 6 pin stuff. |
Lo-Fi Version | Time is now: 5th June 2024 - 01:58 AM |
