Loosening striker plate - how much force is okay? |
smontanaro |
Jan 8 2007, 05:57 PM
Senior Member Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest |
The right side door on my /6 doesn't close well (doesn't close completely, tends to open at inopportune left-hand moments). There's no sag that I can see. (The car passes the 200lb butt test.) If I understand correctly the trick is to loosen the striker plate screws and adjust it by trial-and-error. Trouble is, if I loosen the screws the plate behind the door jamb that they screw into seems fixed in place. Is that supposed to move? How much persuasion can I apply without damaging something?
Thx, Skip |
smontanaro |
Apr 22 2007, 08:11 PM
Problem solved! Went back out after dinner this evening. Hung the panel just by the three clips. Door closed fine. I then pushed in the little plastic clips while the door was closed. Still fine. Then I attached the grab handle loosely. Still good. Snug things up. Closes like a champ. Finally, I reinstalled the little chrome trim thingie around the handle. We're good to go!!!
Skip |
Lo-Fi Version | Time is now: 3rd June 2024 - 09:36 AM |
