malaga_red75 |
'74 2.5L N/A Subie ![]() ![]() Group: Members Posts: 454 Joined: 5-March 06 From: Menlo Park, CA Member No.: 5,674 Region Association: None ![]() |
Hey, so I just got my new to me center console....(Thanks Sean!!!!)
So, first thing i did was pull the gauges from the panel and test them. They all work!! clock still ticks, volt still works and the temp worked on accident as my dad and i touched the green wire to a power and the temp needle sweeped up.....anywyas. I found some wires under the carpet, above the center tube, are these the wires for the gauges?? heres a picture. Thanks in advance!! Attached image(s) ![]() |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Under the battery somewhere should be a single-wire plastic box connector, similar to the ones in your picture above. The wire connects there to another green/black wire that runs across the front of the engine under the engine tin, and winds up going into the "taco plate" at the left-front corner of the bottom of the motor.
--DD |
Lo-Fi Version | Time is now: 16th June 2024 - 12:04 PM |
