favorite engine drop method, what's yours? |
mightyohm |
Nov 21 2003, 11:02 PM
Advanced Member Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest |
Last time I helped drop a 914 engine, we used the Pelican method of lowering the car almost to the ground and letting the motor plop out onto a furniture dolly. I don't know that I like this method because it really requires 2 jacks and there is no obvious way to get the engine back in when you're done, since you used gravity to help get it out.
I would like to raise and support the car, then lower the engine on my floorjack. But there is obviously going to be a balance problem. I've also heard some people use threaded rods to slowly lower everything but this sounds like too much trouble. So what's the best way? |
JeffBowlsby |
Nov 24 2003, 08:33 AM
914 Wiring Harnesses Group: Members Posts: 8,537 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
QUOTE how do you get the engine BACK in the car again With the threaded rod/furniture dolly method, the engine doesnt 'drop' to the dolly. The car sits on its wheels on ramps, nice and steady like. Each 3/8 inch threaded rod (you use 2) is good for at least 1000 lbs, so there is no safety problem. "Reinstall is the reverse of removal." |
Lo-Fi Version | Time is now: 12th June 2024 - 03:52 PM |
