Center Console wiring, Help me!!! |
malaga_red75 |
Apr 24 2007, 10:14 PM
'74 2.5L N/A Subie Group: Members Posts: 454 Joined: 5-March 06 From: Menlo Park, CA Member No.: 5,674 Region Association: None |
Hey, so I just got my new to me center console....(Thanks Sean!!!!)
So, first thing i did was pull the gauges from the panel and test them. They all work!! clock still ticks, volt still works and the temp worked on accident as my dad and i touched the green wire to a power and the temp needle sweeped up.....anywyas. I found some wires under the carpet, above the center tube, are these the wires for the gauges?? heres a picture. Thanks in advance!! Attached image(s) |
Cap'n Krusty |
Apr 26 2007, 12:30 AM
Left front corner of the bottom of the engine case, mounted in the cover there. You probably don't have one. Needs to be the correct sender for the gauge, and the mounting plates (2 pieces w/a gasket in between) are pretty available used. New, the set is about $125 without the sender. The Cap'n
Lo-Fi Version | Time is now: 8th June 2024 - 12:41 PM |
