jd66921 |
Member ![]() ![]() Group: Members Posts: 316 Joined: 9-January 06 From: Texas Member No.: 5,394 ![]() |
Hi,
I seem to have the strangest problems. I set up my new engine, and was putting the transmission back on. I had already put the clutch in. Everything was fine. Then, I slid the transmission back on, and the clutch release fork just swung freely!! WTF?? The clutch plate is fine, and installed correctly. It only goes in one way. Both pressure plates I have look identical. The throwout bearing looks right, and I don't think any parts are missing. I think I got the transmission on far enough. My measurements say it should have worked! Am I missing something?? Sorry for the stupid questions!! Thanks, Jeff |
shaggy |
mechanic/welder/fabricator ![]() ![]() ![]() Group: Members Posts: 702 Joined: 26-September 05 From: Gilbert, AZ Member No.: 4,869 Region Association: None ![]() |
Hi, I seem to have the strangest problems. I set up my new engine, and was putting the transmission back on. I had already put the clutch in. Everything was fine. Then, I slid the transmission back on, and the clutch release fork just swung freely!! WTF?? The clutch plate is fine, and installed correctly. It only goes in one way. Both pressure plates I have look identical. The throwout bearing looks right, and I don't think any parts are missing. I think I got the transmission on far enough. My measurements say it should have worked! Am I missing something?? Sorry for the stupid questions!! Thanks, Jeff did you get it on far enough to bolt it up? if not the TO bearing could be just sliding on the main shaft. |
Lo-Fi Version | Time is now: 10th June 2024 - 07:59 PM |
