Transmission replacement, Clutch doesn't disengage? |
jd66921 |
Apr 26 2007, 01:39 PM
Member Group: Members Posts: 316 Joined: 9-January 06 From: Texas Member No.: 5,394 |
Hi,
I seem to have the strangest problems. I set up my new engine, and was putting the transmission back on. I had already put the clutch in. Everything was fine. Then, I slid the transmission back on, and the clutch release fork just swung freely!! WTF?? The clutch plate is fine, and installed correctly. It only goes in one way. Both pressure plates I have look identical. The throwout bearing looks right, and I don't think any parts are missing. I think I got the transmission on far enough. My measurements say it should have worked! Am I missing something?? Sorry for the stupid questions!! Thanks, Jeff |
RoadGlue |
Apr 27 2007, 12:31 AM
Sonoma County Gear Head Group: Admin Posts: 2,033 Joined: 8-January 03 From: Santa Rosa, CA Member No.: 108 Region Association: Northern California |
How much slop do you have in the arm? It's not supposed to be tight until the cable is installed. It should move back and forth a bit. Got a tape measure?
Lo-Fi Version | Time is now: 10th June 2024 - 11:09 PM |
