favorite engine drop method, what's yours? |
mightyohm |
Nov 21 2003, 11:02 PM
Advanced Member Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest |
Last time I helped drop a 914 engine, we used the Pelican method of lowering the car almost to the ground and letting the motor plop out onto a furniture dolly. I don't know that I like this method because it really requires 2 jacks and there is no obvious way to get the engine back in when you're done, since you used gravity to help get it out.
I would like to raise and support the car, then lower the engine on my floorjack. But there is obviously going to be a balance problem. I've also heard some people use threaded rods to slowly lower everything but this sounds like too much trouble. So what's the best way? |
JeffBowlsby |
Nov 24 2003, 02:03 PM
914 Wiring Harnesses Group: Members Posts: 8,537 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
QUOTE With the threaded rod method do you just put two rods on the ends of the engine mount bar and let the transmission end hang? Yep, but support the trans with a floor jack and lower it down as the engine bar comes down to keep the drivetrain level. Be sure to space the ramps out far enough to allow you to slide the engine bar out from under the car so it will clear the ramps. |
Lo-Fi Version | Time is now: 13th June 2024 - 04:09 AM |
