| obscurity |
Apr 18 2007, 06:59 PM
Member ![]() ![]() Group: Members Posts: 412 Joined: 24-February 06 From: Atlanta ,GA Member No.: 5,628 Region Association: South East States |
Just trying to improve my welding before I tackle the car and I had a few questions.
1. what do you think? I know it is pretty messy but it is a world apart from where I started. 2. Once you have blown a hole in the metal how do you go about filling it? I have tried "stitching" across the hole but all I seem to do is move the hole around (fill one area and make more hole in another. It seems this will become a critical skill when I get to the car and the new piece doesn't fit perfectly. I'll need to fill some gaps 3. What are the little pock morks on the top of each weld? Is it to be expected from metal shrinking or should I adjust my technique. this is both sides of the same weld. ![]() I should mention that I am using a Lincoln Electric (HD special) Mig welder with 75%Ar/25%CO2 gas Thanks for any pointers, John |
| IronHillRestorations |
Apr 29 2007, 06:40 PM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,926 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
It's all about developing your technique.
More practice! About three more hours, at least. Until you can make better looking welds, you don't need to touch your car with it. You want better looking welds with good penetration, but not too much to grind off. It looks to me like you've got the wire feed speed too high, which makes for a bigger bead. This will help prevent blowing through, but aslo alot of grinding, and less penetration. You want to melt the two pieces of metal together with as little bead as possible, with the least amount of warpage. Simple right? That's why the three hours of practice. When I took a TIG welding class, all I did for the first twelve hours was make surface beads. That's it for twelve hours. I'm pretty good with a MIG too. You are using a real MIG with gas right? No gas, it's not MIG. |
| obscurity |
Apr 29 2007, 06:54 PM
It's all about developing your technique. More practice! About three more hours, at least. Until you can make better looking welds, you don't need to touch your car with it. You want better looking welds with good penetration, but not too much to grind off. It looks to me like you've got the wire feed speed too high, which makes for a bigger bead. This will help prevent blowing through, but aslo alot of grinding, and less penetration. You want to melt the two pieces of metal together with as little bead as possible, with the least amount of warpage. Simple right? That's why the three hours of practice. When I took a TIG welding class, all I did for the first twelve hours was make surface beads. That's it for twelve hours. I'm pretty good with a MIG too. You are using a real MIG with gas right? No gas, it's not MIG. Yes it is MIG with Argon/CO2 mix I was pretty happy with this section. I thought the penetration was pretty good. You don't think so huh? ![]() The rest is definitely crap and is the result of burning through and then trying to fix it without grinding the high spots off first. I suppose I should try moving the amperage down to "A" and slowing the wire speed down a little more. I don't think I can turn the wire speed down at the higher amp setting and not burn through every time. I suppose I am just getting impatient. Thanks for the input, John |
obscurity weld critique Apr 18 2007, 06:59 PM
Andyrew YOu need a copper block or brass or even aluminum.... Apr 18 2007, 07:06 PM
scotty b First off let the metal cool COMPLETELY before try... Apr 18 2007, 07:18 PM
scotty b Something else to note. You will be best off NOT t... Apr 18 2007, 07:28 PM
scotty b Well this poisses me off because the pic came out ... Apr 18 2007, 07:30 PM
scotty b after the wleding I knock the tops off with my cut... Apr 18 2007, 07:32 PM
scotty b You can also tell how little heat I allowed to bui... Apr 18 2007, 07:36 PM
SGB Thanks for the info. Very nice work. I appreciat... Apr 18 2007, 08:57 PM
sww914 If you're welding outer body panels, weld 1/4... Apr 18 2007, 09:07 PM
obscurity Thanks for all the replies. tomorrow I will try t... Apr 18 2007, 09:27 PM
r_towle Turn your voltage down and wire speed down.
Now y... Apr 18 2007, 10:39 PM
obscurity Well I practiced a little more today and this is w... Apr 29 2007, 03:47 PM
obscurity
How about this one? Things went a little off th... Apr 29 2007, 04:40 PM
r_towle
[quote name='9146986' post='894517' date='Apr 29 ... Apr 29 2007, 10:21 PM
9146986
[quote name='9146986' post='894517' date='Apr 29 ... Apr 30 2007, 07:27 PM
JPB MIG welding sheet metal is a PITA and you should b... Apr 29 2007, 07:21 PM
Spoke Your welds look pretty good to me. Then again, I s... Apr 29 2007, 07:30 PM
JPB HOLLY SREAMING BLOOD AND GUTS!!!! ... Apr 29 2007, 07:39 PM
bigkensteele You are already better than me, but I will go ahea... Apr 29 2007, 08:26 PM
John
You are already better than me, but I will go ahe... Apr 29 2007, 08:47 PM
scotty b :agree: the highlighted areas are looking much be... May 1 2007, 07:47 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:58 PM |
