| obscurity |
Apr 18 2007, 06:59 PM
Member ![]() ![]() Group: Members Posts: 412 Joined: 24-February 06 From: Atlanta ,GA Member No.: 5,628 Region Association: South East States |
Just trying to improve my welding before I tackle the car and I had a few questions.
1. what do you think? I know it is pretty messy but it is a world apart from where I started. 2. Once you have blown a hole in the metal how do you go about filling it? I have tried "stitching" across the hole but all I seem to do is move the hole around (fill one area and make more hole in another. It seems this will become a critical skill when I get to the car and the new piece doesn't fit perfectly. I'll need to fill some gaps 3. What are the little pock morks on the top of each weld? Is it to be expected from metal shrinking or should I adjust my technique. this is both sides of the same weld. ![]() I should mention that I am using a Lincoln Electric (HD special) Mig welder with 75%Ar/25%CO2 gas Thanks for any pointers, John |
| Spoke |
Apr 29 2007, 07:30 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,370 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
Your welds look pretty good to me. Then again, I suck at welding but it sure is fun.
Check out this nightmare. Luckily, after some grinding it didn't look too bad and a bit of bondo covered everything up. Attached image(s)
obscurity weld critique Apr 18 2007, 06:59 PM
Andyrew YOu need a copper block or brass or even aluminum.... Apr 18 2007, 07:06 PM
scotty b First off let the metal cool COMPLETELY before try... Apr 18 2007, 07:18 PM
scotty b Something else to note. You will be best off NOT t... Apr 18 2007, 07:28 PM
scotty b Well this poisses me off because the pic came out ... Apr 18 2007, 07:30 PM
scotty b after the wleding I knock the tops off with my cut... Apr 18 2007, 07:32 PM
scotty b You can also tell how little heat I allowed to bui... Apr 18 2007, 07:36 PM
SGB Thanks for the info. Very nice work. I appreciat... Apr 18 2007, 08:57 PM
sww914 If you're welding outer body panels, weld 1/4... Apr 18 2007, 09:07 PM
obscurity Thanks for all the replies. tomorrow I will try t... Apr 18 2007, 09:27 PM
r_towle Turn your voltage down and wire speed down.
Now y... Apr 18 2007, 10:39 PM
obscurity Well I practiced a little more today and this is w... Apr 29 2007, 03:47 PM
obscurity
How about this one? Things went a little off th... Apr 29 2007, 04:40 PM
9146986 It's all about developing your technique.
Mor... Apr 29 2007, 06:40 PM
obscurity
Mo... Apr 29 2007, 06:54 PM
r_towle
[quote name='9146986' post='894517' date='Apr 29 ... Apr 29 2007, 10:21 PM
9146986
[quote name='9146986' post='894517' date='Apr 29 ... Apr 30 2007, 07:27 PM
JPB MIG welding sheet metal is a PITA and you should b... Apr 29 2007, 07:21 PM
JPB HOLLY SREAMING BLOOD AND GUTS!!!! ... Apr 29 2007, 07:39 PM
bigkensteele You are already better than me, but I will go ahea... Apr 29 2007, 08:26 PM
John
You are already better than me, but I will go ahe... Apr 29 2007, 08:47 PM
scotty b :agree: the highlighted areas are looking much be... May 1 2007, 07:47 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:28 PM |
