| r_towle |
Apr 29 2007, 11:28 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Hi there,
So over the years I have seen all sorts of ideas, lots of products etc.. Seems like we are chasing our tails. Here is my dilema, and I would like to get some input. Take a 34 year old chassis, fix the rust. Add super stiff suspension. Bearings, bars etc. add really sticky rubber. Now, what gives in the chassis...where is the weak spot. Say I seam weld the suspension console. What next...something needs to flex, or it seems to me that something will break instead. I ahve seen pics from McMark of a cracked long inside, and in the miidle of the span..not a rust issue per se, but a fatigue issue. So, where can I engineer in flex, so the chassis wont crack, or break a weld. No Cage allowed. Just the chassis. Currently there is not inner long kit, or outer...just good repair work on the rust to date... Nothing is cracked yet...but something will have to give.. I just put in roller bearings....now its really smooth, but now more of the forces are put directly into the chassis... Rich |
| Crazyhippy |
Apr 29 2007, 11:51 PM
Insert witty comment here... ![]() ![]() ![]() Group: Members Posts: 1,659 Joined: 28-July 05 From: Home of the Coyotes, AZ Member No.: 4,493 Region Association: None |
Weld the dorrs shut to add some more strength?
You are trying to use a 4"x6" sheetmetal tube to keep the while car straight. It just cant keep up w/ modern tires w/o some help. BJH |
r_towle Chassis twist Apr 29 2007, 11:28 PM
No Cage allowed
there's your real problem ...... Apr 29 2007, 11:38 PM
r_towle I think maybe I did not ask the right way.
How ca... Apr 30 2007, 12:16 AM
McMark I think you're looking at it wrong. Yes, the ... Apr 30 2007, 12:32 AM
r_towle
I think you're looking at it wrong. Yes, the... Apr 30 2007, 12:50 AM
DSM Where do you engineer the flex to occur ??? Ever... Apr 30 2007, 07:50 AM
Matt Romanowski DSM has it right. As the chassis gets stiffer, the... Apr 30 2007, 08:26 AM
woobn8r If you look at many newer cars that have been engi... Apr 30 2007, 08:29 AM
Brando Put in a cage, stiffen up the chassis. Let the sus... Apr 30 2007, 03:04 PM
JPB Crap thats symple! No role cage is no big dea... Apr 30 2007, 06:37 PM
ChrisNPDrider My degree is in toxicology, not engineering, but a... Apr 30 2007, 07:31 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:47 AM |
