smj |
"Dude, Steve from Berkeley." ![]() ![]() ![]() Group: Members Posts: 591 Joined: 28-August 05 From: Berkeley, CA Member No.: 4,691 Region Association: Northern California ![]() ![]() |
So a month or two ago I went four or maybe six weeks without running the 3.0l SC motor in my 914-6. I had been firing it up every other weekend, but things happened.... Anyway, no joy regardless of where the hand throttle sits. Every now and again it taunts me by sounding as if it fired on one revolution.
The motor is carbed, not fuel injected. Plenty of juice in the battery, the starter motor is happy to turn, there's gas in the tank. I know I need fuel, air, and spark -- the question is how to check that these things are getting to where they need to go. I feel a thrumming in the engine bay fuel lines when the key is in the right position, and I can hear the fuel pump running. How do I confirm that I'm getting a pulse to the spark plugs without a clamp-type electrical meter? Links to tutorials would be welcome. I did try a couple of searches before posting, but the keywords I used must've been way too broad... Thanks, --Steve. |
smj |
Summary: Today it turned over. No real explanation, but it worked.
I'd tried most of what was suggested in this thread, and had gotten to the point of going to Kragen and buying a spark plug specifically to check for spark w/o trying to remove one of the installed plugs. And then for a couple weeks I just didn't want to deal with it. Today, worrying that if I let it sit much longer without even cranking the motor Bad Things would start to happen, I gave the -6 another try. For the second attempt I put the hand throttle all the way down -- and it stumbled after a couple revs. Hmmm... Tried it again, nothing. Started slowly raising the hand throttle, cranking, raising a little more, trying. On the third or fourth attempt, it caught and ran on it's own, anemicly, for a little bit. Hmmm... Well, eventually I got it to fire and run. And in the process I filled the garage with the most godawful stench and grey smoke you'd ever want to behold! (IMG:style_emoticons/default/icon8.gif) I'm sure the neighbors love me, whooping and hollering while a foul-smelling cloud wafts out over their houses... By the by, the fluid trickling out of the tailpipe was greyish -- hard to say what if anything it smelled like,given what else was in the air at the time. Anyway, the car smoked like a Navy destroyer laying down cover, but it didn't sound too bad so after spreading my smokey idea of joy through the neighborhood for a while I took to the highway to try and get everything warmed up properly. That tailshifter's still a pain in the ass, but the car felt pretty good otherwise and I think by the end the only smoke was the usual problem I have with condensate from the oil tank filter/breather widget dripping down onto the exhaust. Just wanted to close out this particular episode, and again thank everybody for their help. Hopefully nobody's reported me to the DMV as a result of tonight's adventure. Now, do I rebuild this lump or replace it with something that's got EFI... --S. |
Lo-Fi Version | Time is now: 11th July 2025 - 08:33 AM |
