> More troubleshooting help needed..., this is getting not so much fun
lotus_65
post May 8 2007, 09:42 AM
'74 2056 + dual 40's, mallory + blue coil internally ballasted.
So, because I just can't get the carbs right, I had a mechanic do it. The car ran great for about 300 miles and then started missing. I have gone through ignition, tested or swapped with known working replacements and the miss remains. I tested the mallory according to the instructions here: unilite module testing. It passed all those checks.
I did a fuel flow test to the carbs. flow at under 1lb is a little shy to the 3&4 side, but at 2, where I run the regulator normally it's effectively even flow. I pressurized the system and got 3lb's max (my return line is calibrated for that). Both carbs seem to be feeding fuel appropriately.
I can unplug wires 1&2, and the car still idles @<300rpm. Unplugging either 3 or 4 causes the engine to die.
Here's the weird part: I can almost get the idle correct by holding the plug wires on 1 & 2 about a quarter inch from the tops of the plugs. That is to say that the idle comes up momentarily, and waivers depending on if ignition gets through the plug in time.
I've replaced more plugs in the last year than I'd care to admit, and I broke my CSOB plug wrench or else I would have a report on those too. I can't see how they'd go bad though.
Ignition or fuel?
TIA for the help!
Paul
952.451.5205
lotus_65
post May 8 2007, 12:32 PM
it's at the top of the list now, rhodyguy.
I'm going back to my guy and ask him about this. It's something he should fix gratis I'd hope.
Paul
lotus_65   More troubleshooting help needed...   May 8 2007, 09:42 AM
904svo   Sounds like the carburator is out of sync at idle,...   May 8 2007, 10:17 AM
lotus_65   Actually, before I started messing with the carbs ...   May 8 2007, 10:41 AM
So.Cal.914   Sounds like your running rich on 1&2, that wou...   May 8 2007, 11:03 AM
lotus_65   3&4 look gud. This is a long-standing issue wi...   May 8 2007, 11:09 AM
toon1   I'm taking a wild assed guess, but, 3&4 ar...   May 8 2007, 11:21 AM
rhodyguy   do you own the synconometer that has the numbered ...   May 8 2007, 11:21 AM
lotus_65   it's at the top of the list now, rhodyguy. I...   May 8 2007, 12:32 PM
iamchappy   Check your plug wires and your coil wire. If you ...   May 8 2007, 12:45 PM
lotus_65   Thanks, Chappy. I swapped everything except mallor...   May 8 2007, 01:05 PM
akellym   If you ever need any help, there's plenty of r...   May 8 2007, 01:14 PM
lotus_65   Thanks, Kelly. How are you? Is the car getting it...   May 8 2007, 01:19 PM
akellym   No paint yet. I want to finish this season, so it...   May 8 2007, 01:24 PM
lotus_65   I haven't joined Nord Stern but I'll come ...   May 8 2007, 02:35 PM
akellym   It's open to the public I believe, you just ha...   May 8 2007, 02:51 PM
iamchappy   Greg Smith knows what he is doing, been around a l...   May 8 2007, 02:55 PM
lotus_65   Yep, I think he does know a fair amount. I just sp...   May 8 2007, 03:26 PM
iamchappy   No, but your still welcome to the extra carb synce...   May 8 2007, 04:33 PM
Carlitos Way   I was once told (and I'm not sure if this is c...   May 8 2007, 04:51 PM
Gint   I was once told (and I'm not sure if this is ...   May 8 2007, 05:55 PM
akellym   Here's my example, fuel Y block right in the m...   May 8 2007, 06:17 PM
lotus_65   Mine are really close to the same length. I have a...   May 8 2007, 06:23 PM
lotus_65   Kelly, mine's not as attractive but functional...   May 8 2007, 06:34 PM
- Lo-Fi Version Time is now: 12th July 2025 - 10:59 AM
