2.0L Piston Rings, How to.. |
orcadigital |
May 8 2007, 03:35 PM
Member Group: Members Posts: 59 Joined: 1-November 05 From: Elizabeth, CO Member No.: 5,043 |
Due to some poor leak down numbers, mostly ring related, i was wondering what was entailed in replacing piston rings.
I have a cylinder hone and plan on honing the cylinders, then checking for taper or anything worrisome (i have 2 complete sets of pistons and cylinders, used but no scarring or any visible damage), then installing new rings. I am wondering what concerns or things i should check. Also, as car as a ring compressor. I have a band type, but usually you put it on, then lightly hammer the piston into the cylinder. As this setup is a tad different (the sleeve slides over the piston), is there anything i need to worry about? I am in a bit of a time crunch, thus i am going this way, while i build up an engine that i can swap in later in the year, which will have new P's and C's. Thanks! |
Jake Raby |
May 9 2007, 12:34 PM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
Jake, I definately agree, and the only reason i am doing this is to have a car going in 2 weeks.
QUOTE Jake, I definately agree, and the only reason i am doing this is to have a car going in 2 weeks. NEVER, ever alow time constraints to dictate your engine plans- doing so is almost guaranteed failure. |
Lo-Fi Version | Time is now: 15th June 2024 - 10:04 PM |
