Oil leak |
Oil leak |
jonferns |
May 11 2007, 08:33 PM
Advanced Member Group: Members Posts: 2,081 Joined: 29-March 07 From: New Jersey Member No.: 7,631 Region Association: North East States |
Oil leak on the new 914, thinking pushrod tubes or oil cooler? Filter is tight and valve covers seem dry. Any suggestions?
brp914 |
May 11 2007, 09:43 PM
Unregistered |
best case scenario (that I can think of): oil pressure switch. use flashlight and look in hole in sheet metal next to distributor. If oil is leaking from there it is probably leaking from between the metal/plastic joint. get a new switch from porsche dealer. If you get a cheapo "hecho en mexico" you'll repeat this in a few weeks. careful when tightening it - you'll need ~24mm(?) to r/r. it has fine threads and easily stripped, if not already.
unhappy scenario (happened to me): case oil galley plug is coming out. when it actually pops out it lead to total oil loss quickly. engines needs to come out. In the future, if the engine ever needs to come out for any reason, have the 2 plugs above the filter console, as well as the ones on the back behind the flywheel tapped and plugged. good luck |
Lo-Fi Version | Time is now: 13th June 2024 - 01:57 AM |
