| Mike D. |
May 15 2007, 05:43 PM
OK, It runs now, and pretty good too! ![]() ![]() ![]() Group: Members Posts: 1,457 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None
My last six conversion was with an early 2.0 6 so I was fine with the stock 914 4 regulator on the relay board. The engine I am installing now is a 3.0 sc with the internal reg. alt. so now I'm a little confused as to what I should do on the relay board. Do I need to run a jumper wire somewhere?
I know someone out there has BTDT. Thanks, |
| Series9 |
May 15 2007, 08:34 PM
Lesbians taste like chicken. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,453 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States |
The finished connection:
Mike D. Six Conversion and the Voltage Regulator May 15 2007, 05:43 PM
iamchappy I just run it without the relay board voltage regu... May 15 2007, 06:16 PM
john rogers After waiting for a couple of years, I finally rep... May 15 2007, 06:33 PM
Gint
After waiting for a couple of years, I finally re... May 16 2007, 02:56 PM
Series9
Question...
Rather than buy an expensive female ... May 16 2007, 03:08 PM
Gint
Question...
Rather than buy an expensive female... May 16 2007, 04:15 PM
Series9
Ok then... Where can I get a male version?
I... May 16 2007, 04:38 PM
Gint
I... May 16 2007, 06:06 PM
johnlush
Mi... May 16 2007, 05:54 PM
Series9 It's not hard. Remove the board and regulator... May 15 2007, 08:09 PM
Series9 Here's a picture of the male 14-pin on Waide... May 15 2007, 08:16 PM
Mike D.
Thanks Joe! May 16 2007, 01:29 PM
Eric_Shea Excellent info :trophy: May 16 2007, 01:51 PM
SLITS If you get the Porsche Technical Bulletin 1, Model... May 16 2007, 02:48 PM
Eric_Shea Can you post it? May 16 2007, 02:51 PM
SLITS
Can you post it?
I'll see if it will scan t... May 16 2007, 03:07 PM
Series9
Can you post it?
May 16 2007, 03:11 PM
Eric_Shea
Just re-type it... <_<
:type3d: May 16 2007, 03:11 PM
Series9 and: May 16 2007, 03:12 PM
Eric_Shea Once again, Joe saves yur ass... May 16 2007, 03:13 PM
Series9
I owe him ple... May 16 2007, 03:21 PM
Eric_Shea
Don't tell him that... he'll get all coc... May 16 2007, 03:27 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th April 2026 - 10:11 AM |
