> Six Conversion and the Voltage Regulator, SC Alt. has built in Reg. what to do about relay board
Mike D.
post May 15 2007, 05:43 PM
OK, It runs now, and pretty good too!
My last six conversion was with an early 2.0 6 so I was fine with the stock 914 4 regulator on the relay board. The engine I am installing now is a 3.0 sc with the internal reg. alt. so now I'm a little confused as to what I should do on the relay board. Do I need to run a jumper wire somewhere?
I know someone out there has BTDT.
Thanks,
Eric_Shea
post May 16 2007, 03:11 PM
PMB Performance
I'll see if it will scan tonight ...... don't have a scanner at work (that's hooked up)
Just re-type it... (IMG:style_emoticons/default/dry.gif)
(IMG:style_emoticons/default/40.gif)
Mike D.   Six Conversion and the Voltage Regulator   May 15 2007, 05:43 PM
iamchappy   I just run it without the relay board voltage regu...   May 15 2007, 06:16 PM
john rogers   After waiting for a couple of years, I finally rep...   May 15 2007, 06:33 PM
Gint   After waiting for a couple of years, I finally re...   May 16 2007, 02:56 PM
Series9   Question... Rather than buy an expensive female ...   May 16 2007, 03:08 PM
Gint   Question... Rather than buy an expensive female...   May 16 2007, 04:15 PM
Series9   Ok then... Where can I get a male version? I...   May 16 2007, 04:38 PM
Gint   Ok then... Where can I get a male version? I...   May 16 2007, 06:06 PM
johnlush   Ok then... Where can I get a male version? Mi...   May 16 2007, 05:54 PM
Series9   It's not hard. Remove the board and regulator...   May 15 2007, 08:09 PM
Series9   Here's a picture of the male 14-pin on Waide...   May 15 2007, 08:16 PM
Series9   The finished connection:   May 15 2007, 08:34 PM
Mike D.   The finished connection: Thanks Joe!   May 16 2007, 01:29 PM
Eric_Shea   Excellent info :trophy:   May 16 2007, 01:51 PM
SLITS   If you get the Porsche Technical Bulletin 1, Model...   May 16 2007, 02:48 PM
Eric_Shea   Can you post it?   May 16 2007, 02:51 PM
SLITS   Can you post it? I'll see if it will scan t...   May 16 2007, 03:07 PM
Series9   Can you post it?   May 16 2007, 03:11 PM
Eric_Shea   Just re-type it... <_< :type3d:   May 16 2007, 03:11 PM
Series9   and:   May 16 2007, 03:12 PM
Eric_Shea   Once again, Joe saves yur ass...   May 16 2007, 03:13 PM
Series9   Once again, Joe saves yur ass... I owe him ple...   May 16 2007, 03:21 PM
Eric_Shea   Don't tell him that... he'll get all coc...   May 16 2007, 03:27 PM
- Lo-Fi Version Time is now: 14th April 2026 - 10:10 AM
