> Six Conversion and the Voltage Regulator, SC Alt. has built in Reg. what to do about relay board
Mike D.
post May 15 2007, 05:43 PM
OK, It runs now, and pretty good too!
My last six conversion was with an early 2.0 6 so I was fine with the stock 914 4 regulator on the relay board. The engine I am installing now is a 3.0 sc with the internal reg. alt. so now I'm a little confused as to what I should do on the relay board. Do I need to run a jumper wire somewhere?
I know someone out there has BTDT.
Thanks,
john rogers
post May 15 2007, 06:33 PM
After waiting for a couple of years, I finally replaced mine with a pair of water proof electrical connectors so that all the connectors from the input side were still connected to the output side as I use them for other things. If you use the diagram on the Pelican site or in the Haynes manual you can match color to color.
Gint
post May 16 2007, 02:56 PM
Mike Ginter
QUOTE(john rogers @ May 15 2007, 05:33 PM) *
Question...
Rather than buy an expensive female connector to match that very expensive male connector, why not replace it with a modern alternative?
Series9
post May 16 2007, 03:08 PM
Lesbians taste like chicken.
QUOTE(Gint @ May 16 2007, 02:56 PM) *
Question...
1. $38 isn't very expensive.
2. It's a VERY high quality connector.
3. I've never seen another that will accept the differing sizes of wires necessary to do the job.
4. You would have to replace both sides, instead of one.
5. Most new connectors require a specialized crimping tool to crimp the pins to the wires.
That's why. (IMG:style_emoticons/default/cool.gif)
Gint
post May 16 2007, 04:15 PM
Mike Ginter
QUOTE(Series9 @ May 16 2007, 02:08 PM) *
Question...
Ok then... Where can I get a male version?
Mike D.   Six Conversion and the Voltage Regulator   May 15 2007, 05:43 PM
iamchappy   I just run it without the relay board voltage regu...   May 15 2007, 06:16 PM
john rogers   After waiting for a couple of years, I finally rep...   May 15 2007, 06:33 PM
Gint   After waiting for a couple of years, I finally re...   May 16 2007, 02:56 PM
Series9   Question... Rather than buy an expensive female ...   May 16 2007, 03:08 PM
Gint   Question... Rather than buy an expensive female...   May 16 2007, 04:15 PM
Series9   Ok then... Where can I get a male version? I...   May 16 2007, 04:38 PM
Gint   Ok then... Where can I get a male version? I...   May 16 2007, 06:06 PM
johnlush   Ok then... Where can I get a male version? Mi...   May 16 2007, 05:54 PM
Series9   It's not hard. Remove the board and regulator...   May 15 2007, 08:09 PM
Series9   Here's a picture of the male 14-pin on Waide...   May 15 2007, 08:16 PM
Series9   The finished connection:   May 15 2007, 08:34 PM
Mike D.   The finished connection: Thanks Joe!   May 16 2007, 01:29 PM
Eric_Shea   Excellent info :trophy:   May 16 2007, 01:51 PM
SLITS   If you get the Porsche Technical Bulletin 1, Model...   May 16 2007, 02:48 PM
Eric_Shea   Can you post it?   May 16 2007, 02:51 PM
SLITS   Can you post it? I'll see if it will scan t...   May 16 2007, 03:07 PM
Series9   Can you post it?   May 16 2007, 03:11 PM
Eric_Shea   Just re-type it... <_< :type3d:   May 16 2007, 03:11 PM
Series9   and:   May 16 2007, 03:12 PM
Eric_Shea   Once again, Joe saves yur ass...   May 16 2007, 03:13 PM
Series9   Once again, Joe saves yur ass... I owe him ple...   May 16 2007, 03:21 PM
Eric_Shea   Don't tell him that... he'll get all coc...   May 16 2007, 03:27 PM
- Lo-Fi Version Time is now: 14th April 2026 - 10:09 AM
