| BahnBrenner914 |
May 15 2007, 07:39 PM
The girl is gone and all I have now is a beat-up teener ![]() ![]() Group: Members Posts: 301 Joined: 22-May 04 From: Gig Harbor and University Place, WA :: School in Angola, IN :: girlfriend in Sarasota, FL Member No.: 2,094 Region Association: None |
Ok, so my '76 2.0 that I've been working on forever is now once again calling my attention, now that I'm back from college for the summer.... (IMG:style_emoticons/default/cool.gif)
Last summer, we painted it and made it all pretty, (IMG:style_emoticons/default/drooley.gif) but that's not too important when it wont go anywhere to begin with. So when I took it out to try and figure out my phantom 4th gear problem (another thread i'll start when this one is resolved (IMG:style_emoticons/default/headbang.gif) ) I noticed it had no (and I mean none at all (IMG:style_emoticons/default/yellowsleep[1].gif) ) power when I was mashing the gas in 2nd and 3rd gears. And going up hill was barely possible, I kept it floored and it 'surged' on and off (several seconds on then several off) up the hill at an average speed of about 5mph. But I had to leave for school and then it started when I came back. I took the car out a week ago (IMG:style_emoticons/default/driving-girl.gif) , it seemed to pull really well (though maybe not as warm as before) and only stuttered a little at like 4500 rpm. The idle is still a bit wacky (sometimes at 2000, other times at 1000-1100). And I noticed that if I blip the trottle, it will jump up to 3000 or so real quick, then slowly ( 2+ seconds) return to idle. I checked for vacuum leaks and everything "looks" alright. (IMG:style_emoticons/default/laugh.gif) I noticed if I disconnected the vacuum hose from the base of the throttle body 'platform' that leads over to the... well I dont know what it is (IMG:style_emoticons/default/unsure.gif) (silver, about the size of a peanut butter jar with vacuum, fuel?, and computer hookup) that when it was plugged at the throttle body, the engine revved up and down at regular speed. (IMG:style_emoticons/default/w00t.gif) Ok, enough writing. I'm no where near a 914 expert, but I am an engineering student and I'll be damned if I cant fix this. (IMG:style_emoticons/default/headbang.gif) |
| TheCabinetmaker |
May 17 2007, 06:25 AM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Just get new points and adjust them properly and see if that helps before you spend 80 bucks on the pertronics.
| SGB |
May 17 2007, 06:54 AM
just visiting ![]() ![]() ![]() ![]() Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
Just get new points and adjust them properly and see if that helps before you spend 80 bucks on the pertronics. Pertronix are worth it, but I have to agreee that it will just put another variable in the problem. Try points, and if it fixes the prob, get a pertronix when you have the $. |
BahnBrenner914 Another Djet problem May 15 2007, 07:39 PM
r_towle Start with the basics
First off, make sure your p... May 15 2007, 10:25 PM
BahnBrenner914 Well after posting, I got back out there and check... May 15 2007, 10:38 PM
bd1308 Maybe part of the problem is that you have fuel li... May 16 2007, 06:36 AM
tdgray
Maybe part of the problem is that you have fuel l... May 16 2007, 07:15 AM
mrhurtalot hope your car doesnt have the tainted peanut butte... May 16 2007, 08:47 AM
Bleyseng sounds like you got it fixed. Replace the points w... May 16 2007, 10:43 AM
BahnBrenner914
sounds like you got it fixed. Replace the points ... May 16 2007, 12:53 PM
2-OH! Replaces Points & Condenser...
2-OH! May 16 2007, 01:47 PM
BahnBrenner914 Alright, well I looked at the points and cap and l... May 16 2007, 07:55 PM
BahnBrenner914 and here's the pics (hopefully) : May 16 2007, 08:16 PM
BahnBrenner914 and another May 16 2007, 08:16 PM
BahnBrenner914 I went around today and drove the car around town ... May 16 2007, 10:37 PM
Dr Evil Do you know how to adjust ignition points? Read th... May 16 2007, 11:53 PM
Bleyseng Those points look worn out... toss em and get a pe... May 17 2007, 12:17 AM
bd1308
Those points look worn out... toss em and get a p... May 17 2007, 12:25 PM
BahnBrenner914 As for the avatar pic, my Girlfriend is going to b... May 17 2007, 12:47 AM
McMark Check the timing and check the point gap (or go Pe... May 17 2007, 12:58 AM
BahnBrenner914 I'm strongly considering Pertronix now, and I... May 17 2007, 01:43 AM
Dr Evil I trust Geoff's assessment that the cam is gon... May 17 2007, 12:48 PM
BahnBrenner914 Hold on :WTF: you're telling me there's a... May 17 2007, 01:13 PM
Bleyseng looks like the cam block (circled) on the points i... May 17 2007, 04:58 PM
CLEAN OFF AL THAT GREASY GRIME OFF THE ENGINE... May 17 2007, 05:44 PM
BahnBrenner914
CLEAN OFF AL THAT GREASY GRIME OFF THE ENGINE... May 17 2007, 06:51 PM
BahnBrenner914 Alright, so I went and got a pertronix and install... May 17 2007, 08:35 PM
Dr Evil Didja time it?
Alcohol, to clean out the fuel? :b... May 17 2007, 08:56 PM
r_towle What is the timing set at now?
Does the vacuum adv... May 17 2007, 09:09 PM
BahnBrenner914
Does the vacuum ad... May 17 2007, 11:17 PM
BahnBrenner914 Ok, so I just went out with it :driving: and when... May 17 2007, 09:19 PM
vsg914
Ok, so I just went out with it :driving: and whe... May 17 2007, 09:45 PM
r_towle ok, well, you need to clean the inside of the dist... May 17 2007, 09:37 PM
r_towle http://www.914world.com/bbs2/index.php?sho...tribu... May 17 2007, 09:38 PM
r_towle Did you read the how to clean it link I posted?
Th... May 17 2007, 11:26 PM
BahnBrenner914
I do however agree that you might want to check o... May 17 2007, 11:33 PM
Dr Evil When the CHT is hot the MPS is fully in the circui... May 17 2007, 11:37 PM
Dr Evil Oh, you need to read this site tonight:
http://mem... May 17 2007, 11:38 PM
BahnBrenner914 Ok, so I just tested the ohms on the CHT. I had to... May 18 2007, 04:48 PM
Dr Evil :thumbsup: Sounds like CHT is good. Hunting usualy... May 18 2007, 04:57 PM
BahnBrenner914 Yeah, I had the charcoal canister off when I was t... May 18 2007, 05:11 PM
Dr Evil Must be a 76 thing. In the other cars its on top o... May 18 2007, 07:32 PM
BahnBrenner914 So after it warmed up in the driveway, I took the ... May 18 2007, 07:40 PM
r_towle The AAR valve can be removed.
I put a plug in the ... May 18 2007, 10:43 PM
r_towle Oh, not sure how you are testing the AAR using Ohm... May 18 2007, 10:44 PM
BahnBrenner914 True, I have the AAR out right now soaking to see ... May 18 2007, 11:14 PM
r_towle how does the throttle body look?
Is it clean insid... May 18 2007, 11:28 PM
Dr Evil Remember, if you had the engine adjusted to run wi... May 19 2007, 01:11 AM
BahnBrenner914 I adjusted the idle some when I first started mess... May 19 2007, 01:59 AM
Dr Evil The AAR is realy inconsequential as it is supposed... May 19 2007, 09:27 AM
BahnBrenner914 Well I have a 2.0, so not so easy as the 1.8 in th... May 19 2007, 02:09 PM
Dr Evil Ya didnt read the whole thing dija :rolleyes:
Her... May 19 2007, 02:18 PM
BahnBrenner914 Ok OK, I got the template. It seems my fan doesnt ... May 19 2007, 03:34 PM
Dr Evil Fans are completely interchangable so loss of timi... May 19 2007, 03:49 PM
BahnBrenner914 Alright, I finally found the timing mark after fin... May 19 2007, 06:38 PM
So I took it out for a spin and I still have litt... May 19 2007, 06:44 PM
BahnBrenner914 OK, here's the pics of the engine: May 19 2007, 07:20 PM
BahnBrenner914 and the driver side: May 19 2007, 07:21 PM
Dr Evil You still hae the air injector pipes in the heads ... May 19 2007, 07:38 PM
BahnBrenner914
You still hae the air injector pipes in the heads... May 20 2007, 01:26 PM
Bleyseng you should get Dave Hunt to look at the car as he ... May 20 2007, 01:46 PM
Dr Evil CSV is Cold Start Valve. It is the injector that i... May 20 2007, 01:51 PM
BahnBrenner914
Looking at your picks it seems that it may be a n... May 21 2007, 06:07 PM
Dr Evil
Looking at your picks it seems that it may be a ... May 21 2007, 06:33 PM
Pat Garvey I've been watching this thread, and am amazed ... May 21 2007, 09:01 PM
Dr Evil Aw Pat :hugme:
This is how it used to be around ... May 21 2007, 09:23 PM
BahnBrenner914 Well there's several reasons for my 'stick... May 21 2007, 11:44 PM
McMark Did you ever replace the gas? If you've got o... May 22 2007, 12:35 AM
tdgray I'd be interested in what your plugs look like... May 22 2007, 09:41 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:29 AM |
