| BahnBrenner914 |
May 15 2007, 07:39 PM
The girl is gone and all I have now is a beat-up teener ![]() ![]() Group: Members Posts: 301 Joined: 22-May 04 From: Gig Harbor and University Place, WA :: School in Angola, IN :: girlfriend in Sarasota, FL Member No.: 2,094 Region Association: None |
Ok, so my '76 2.0 that I've been working on forever is now once again calling my attention, now that I'm back from college for the summer.... (IMG:style_emoticons/default/cool.gif)
Last summer, we painted it and made it all pretty, (IMG:style_emoticons/default/drooley.gif) but that's not too important when it wont go anywhere to begin with. So when I took it out to try and figure out my phantom 4th gear problem (another thread i'll start when this one is resolved (IMG:style_emoticons/default/headbang.gif) ) I noticed it had no (and I mean none at all (IMG:style_emoticons/default/yellowsleep[1].gif) ) power when I was mashing the gas in 2nd and 3rd gears. And going up hill was barely possible, I kept it floored and it 'surged' on and off (several seconds on then several off) up the hill at an average speed of about 5mph. But I had to leave for school and then it started when I came back. I took the car out a week ago (IMG:style_emoticons/default/driving-girl.gif) , it seemed to pull really well (though maybe not as warm as before) and only stuttered a little at like 4500 rpm. The idle is still a bit wacky (sometimes at 2000, other times at 1000-1100). And I noticed that if I blip the trottle, it will jump up to 3000 or so real quick, then slowly ( 2+ seconds) return to idle. I checked for vacuum leaks and everything "looks" alright. (IMG:style_emoticons/default/laugh.gif) I noticed if I disconnected the vacuum hose from the base of the throttle body 'platform' that leads over to the... well I dont know what it is (IMG:style_emoticons/default/unsure.gif) (silver, about the size of a peanut butter jar with vacuum, fuel?, and computer hookup) that when it was plugged at the throttle body, the engine revved up and down at regular speed. (IMG:style_emoticons/default/w00t.gif) Ok, enough writing. I'm no where near a 914 expert, but I am an engineering student and I'll be damned if I cant fix this. (IMG:style_emoticons/default/headbang.gif) |
| Bleyseng |
May 17 2007, 04:58 PM
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,037 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
looks like the cam block (circled) on the points is worn out or gone. Get new points, set them to .016 gap when the cam block is at the high lobe of the dizzy shaft.
Retime the motor using a timing lite also CLEAN OFF AL THAT GREASY GRIME OFF THE ENGINE! It will run cooler.... (IMG:style_emoticons/default/chairfall.gif) Attached image(s)
BahnBrenner914 Another Djet problem May 15 2007, 07:39 PM
r_towle Start with the basics
First off, make sure your p... May 15 2007, 10:25 PM
BahnBrenner914 Well after posting, I got back out there and check... May 15 2007, 10:38 PM
bd1308 Maybe part of the problem is that you have fuel li... May 16 2007, 06:36 AM
tdgray
Maybe part of the problem is that you have fuel l... May 16 2007, 07:15 AM
mrhurtalot hope your car doesnt have the tainted peanut butte... May 16 2007, 08:47 AM
Bleyseng sounds like you got it fixed. Replace the points w... May 16 2007, 10:43 AM
BahnBrenner914
sounds like you got it fixed. Replace the points ... May 16 2007, 12:53 PM
2-OH! Replaces Points & Condenser...
2-OH! May 16 2007, 01:47 PM
BahnBrenner914 Alright, well I looked at the points and cap and l... May 16 2007, 07:55 PM
BahnBrenner914 and here's the pics (hopefully) : May 16 2007, 08:16 PM
BahnBrenner914 and another May 16 2007, 08:16 PM
BahnBrenner914 I went around today and drove the car around town ... May 16 2007, 10:37 PM
Dr Evil Do you know how to adjust ignition points? Read th... May 16 2007, 11:53 PM
Bleyseng Those points look worn out... toss em and get a pe... May 17 2007, 12:17 AM
bd1308
Those points look worn out... toss em and get a p... May 17 2007, 12:25 PM
BahnBrenner914 As for the avatar pic, my Girlfriend is going to b... May 17 2007, 12:47 AM
McMark Check the timing and check the point gap (or go Pe... May 17 2007, 12:58 AM
BahnBrenner914 I'm strongly considering Pertronix now, and I... May 17 2007, 01:43 AM
vsg914 Just get new points and adjust them properly and s... May 17 2007, 06:25 AM
SGB
Just get new points and adjust them properly and ... May 17 2007, 06:54 AM
Dr Evil I trust Geoff's assessment that the cam is gon... May 17 2007, 12:48 PM
BahnBrenner914 Hold on :WTF: you're telling me there's a... May 17 2007, 01:13 PM
CLEAN OFF AL THAT GREASY GRIME OFF THE ENGINE... May 17 2007, 05:44 PM
BahnBrenner914
CLEAN OFF AL THAT GREASY GRIME OFF THE ENGINE... May 17 2007, 06:51 PM
BahnBrenner914 Alright, so I went and got a pertronix and install... May 17 2007, 08:35 PM
Dr Evil Didja time it?
Alcohol, to clean out the fuel? :b... May 17 2007, 08:56 PM
r_towle What is the timing set at now?
Does the vacuum adv... May 17 2007, 09:09 PM
BahnBrenner914
Does the vacuum ad... May 17 2007, 11:17 PM
BahnBrenner914 Ok, so I just went out with it :driving: and when... May 17 2007, 09:19 PM
vsg914
Ok, so I just went out with it :driving: and whe... May 17 2007, 09:45 PM
r_towle ok, well, you need to clean the inside of the dist... May 17 2007, 09:37 PM
r_towle http://www.914world.com/bbs2/index.php?sho...tribu... May 17 2007, 09:38 PM
r_towle Did you read the how to clean it link I posted?
Th... May 17 2007, 11:26 PM
BahnBrenner914
I do however agree that you might want to check o... May 17 2007, 11:33 PM
Dr Evil When the CHT is hot the MPS is fully in the circui... May 17 2007, 11:37 PM
Dr Evil Oh, you need to read this site tonight:
http://mem... May 17 2007, 11:38 PM
BahnBrenner914 Ok, so I just tested the ohms on the CHT. I had to... May 18 2007, 04:48 PM
Dr Evil :thumbsup: Sounds like CHT is good. Hunting usualy... May 18 2007, 04:57 PM
BahnBrenner914 Yeah, I had the charcoal canister off when I was t... May 18 2007, 05:11 PM
Dr Evil Must be a 76 thing. In the other cars its on top o... May 18 2007, 07:32 PM
BahnBrenner914 So after it warmed up in the driveway, I took the ... May 18 2007, 07:40 PM
r_towle The AAR valve can be removed.
I put a plug in the ... May 18 2007, 10:43 PM
r_towle Oh, not sure how you are testing the AAR using Ohm... May 18 2007, 10:44 PM
BahnBrenner914 True, I have the AAR out right now soaking to see ... May 18 2007, 11:14 PM
r_towle how does the throttle body look?
Is it clean insid... May 18 2007, 11:28 PM
Dr Evil Remember, if you had the engine adjusted to run wi... May 19 2007, 01:11 AM
BahnBrenner914 I adjusted the idle some when I first started mess... May 19 2007, 01:59 AM
Dr Evil The AAR is realy inconsequential as it is supposed... May 19 2007, 09:27 AM
BahnBrenner914 Well I have a 2.0, so not so easy as the 1.8 in th... May 19 2007, 02:09 PM
Dr Evil Ya didnt read the whole thing dija :rolleyes:
Her... May 19 2007, 02:18 PM
BahnBrenner914 Ok OK, I got the template. It seems my fan doesnt ... May 19 2007, 03:34 PM
Dr Evil Fans are completely interchangable so loss of timi... May 19 2007, 03:49 PM
BahnBrenner914 Alright, I finally found the timing mark after fin... May 19 2007, 06:38 PM
So I took it out for a spin and I still have litt... May 19 2007, 06:44 PM
BahnBrenner914 OK, here's the pics of the engine: May 19 2007, 07:20 PM
BahnBrenner914 and the driver side: May 19 2007, 07:21 PM
Dr Evil You still hae the air injector pipes in the heads ... May 19 2007, 07:38 PM
BahnBrenner914
You still hae the air injector pipes in the heads... May 20 2007, 01:26 PM
Bleyseng you should get Dave Hunt to look at the car as he ... May 20 2007, 01:46 PM
Dr Evil CSV is Cold Start Valve. It is the injector that i... May 20 2007, 01:51 PM
BahnBrenner914
Looking at your picks it seems that it may be a n... May 21 2007, 06:07 PM
Dr Evil
Looking at your picks it seems that it may be a ... May 21 2007, 06:33 PM
Pat Garvey I've been watching this thread, and am amazed ... May 21 2007, 09:01 PM
Dr Evil Aw Pat :hugme:
This is how it used to be around ... May 21 2007, 09:23 PM
BahnBrenner914 Well there's several reasons for my 'stick... May 21 2007, 11:44 PM
McMark Did you ever replace the gas? If you've got o... May 22 2007, 12:35 AM
tdgray I'd be interested in what your plugs look like... May 22 2007, 09:41 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:00 AM |
