> Another Djet problem, and I know you know the answer
BahnBrenner914
post May 15 2007, 07:39 PM
The girl is gone and all I have now is a beat-up teener
From: Gig Harbor and University Place, WA :: School in Angola, IN :: girlfriend in Sarasota, FL
Ok, so my '76 2.0 that I've been working on forever is now once again calling my attention, now that I'm back from college for the summer.... (IMG:style_emoticons/default/cool.gif)
Last summer, we painted it and made it all pretty, (IMG:style_emoticons/default/drooley.gif) but that's not too important when it wont go anywhere to begin with.
So when I took it out to try and figure out my phantom 4th gear problem (another thread i'll start when this one is resolved (IMG:style_emoticons/default/headbang.gif) ) I noticed it had no (and I mean none at all (IMG:style_emoticons/default/yellowsleep[1].gif) ) power when I was mashing the gas in 2nd and 3rd gears. And going up hill was barely possible, I kept it floored and it 'surged' on and off (several seconds on then several off) up the hill at an average speed of about 5mph. But I had to leave for school and then it started when I came back.
I took the car out a week ago (IMG:style_emoticons/default/driving-girl.gif) , it seemed to pull really well (though maybe not as warm as before) and only stuttered a little at like 4500 rpm. The idle is still a bit wacky (sometimes at 2000, other times at 1000-1100). And I noticed that if I blip the trottle, it will jump up to 3000 or so real quick, then slowly ( 2+ seconds) return to idle. I checked for vacuum leaks and everything "looks" alright. (IMG:style_emoticons/default/laugh.gif)
I noticed if I disconnected the vacuum hose from the base of the throttle body 'platform' that leads over to the... well I dont know what it is (IMG:style_emoticons/default/unsure.gif) (silver, about the size of a peanut butter jar with vacuum, fuel?, and computer hookup) that when it was plugged at the throttle body, the engine revved up and down at regular speed. (IMG:style_emoticons/default/w00t.gif)
Ok, enough writing. I'm no where near a 914 expert, but I am an engineering student and I'll be damned if I cant fix this. (IMG:style_emoticons/default/headbang.gif)
Bleyseng
post May 17 2007, 04:58 PM
Aircooled Baby!
looks like the cam block (circled) on the points is worn out or gone. Get new points, set them to .016 gap when the cam block is at the high lobe of the dizzy shaft.
Retime the motor using a timing lite
also CLEAN OFF AL THAT GREASY GRIME OFF THE ENGINE!
It will run cooler.... (IMG:style_emoticons/default/chairfall.gif)
post May 17 2007, 05:44 PM
Resident German
QUOTE(Bleyseng @ May 17 2007, 02:58 PM) *
(IMG:style_emoticons/default/agree.gif) that's mighty dirty! (IMG:style_emoticons/default/icon8.gif)
BahnBrenner914   Another Djet problem   May 15 2007, 07:39 PM
r_towle   Start with the basics First off, make sure your p...   May 15 2007, 10:25 PM
BahnBrenner914   Well after posting, I got back out there and check...   May 15 2007, 10:38 PM
bd1308   Maybe part of the problem is that you have fuel li...   May 16 2007, 06:36 AM
tdgray   Maybe part of the problem is that you have fuel l...   May 16 2007, 07:15 AM
mrhurtalot   hope your car doesnt have the tainted peanut butte...   May 16 2007, 08:47 AM
Bleyseng   sounds like you got it fixed. Replace the points w...   May 16 2007, 10:43 AM
BahnBrenner914   sounds like you got it fixed. Replace the points ...   May 16 2007, 12:53 PM
2-OH!   Replaces Points & Condenser... 2-OH!   May 16 2007, 01:47 PM
BahnBrenner914   Alright, well I looked at the points and cap and l...   May 16 2007, 07:55 PM
BahnBrenner914   and here's the pics (hopefully) :   May 16 2007, 08:16 PM
BahnBrenner914   and another   May 16 2007, 08:16 PM
BahnBrenner914   I went around today and drove the car around town ...   May 16 2007, 10:37 PM
Dr Evil   Do you know how to adjust ignition points? Read th...   May 16 2007, 11:53 PM
Bleyseng   Those points look worn out... toss em and get a pe...   May 17 2007, 12:17 AM
bd1308   Those points look worn out... toss em and get a p...   May 17 2007, 12:25 PM
BahnBrenner914   As for the avatar pic, my Girlfriend is going to b...   May 17 2007, 12:47 AM
McMark   Check the timing and check the point gap (or go Pe...   May 17 2007, 12:58 AM
BahnBrenner914   I'm strongly considering Pertronix now, and I...   May 17 2007, 01:43 AM
vsg914   Just get new points and adjust them properly and s...   May 17 2007, 06:25 AM
SGB   Just get new points and adjust them properly and ...   May 17 2007, 06:54 AM
Dr Evil   I trust Geoff's assessment that the cam is gon...   May 17 2007, 12:48 PM
BahnBrenner914   Hold on :WTF: you're telling me there's a...   May 17 2007, 01:13 PM
Bleyseng   looks like the cam block (circled) on the points i...   May 17 2007, 04:58 PM
SirAndy   CLEAN OFF AL THAT GREASY GRIME OFF THE ENGINE...   May 17 2007, 05:44 PM
BahnBrenner914   CLEAN OFF AL THAT GREASY GRIME OFF THE ENGINE...   May 17 2007, 06:51 PM
BahnBrenner914   Alright, so I went and got a pertronix and install...   May 17 2007, 08:35 PM
Dr Evil   Didja time it? Alcohol, to clean out the fuel? :b...   May 17 2007, 08:56 PM
r_towle   What is the timing set at now? Does the vacuum adv...   May 17 2007, 09:09 PM
BahnBrenner914   What is the timing set at now? Does the vacuum ad...   May 17 2007, 11:17 PM
BahnBrenner914   Ok, so I just went out with it :driving: and when...   May 17 2007, 09:19 PM
vsg914   Ok, so I just went out with it :driving: and whe...   May 17 2007, 09:45 PM
r_towle   ok, well, you need to clean the inside of the dist...   May 17 2007, 09:37 PM
r_towle   http://www.914world.com/bbs2/index.php?sho...tribu...   May 17 2007, 09:38 PM
r_towle   Did you read the how to clean it link I posted? Th...   May 17 2007, 11:26 PM
BahnBrenner914   I do however agree that you might want to check o...   May 17 2007, 11:33 PM
Dr Evil   When the CHT is hot the MPS is fully in the circui...   May 17 2007, 11:37 PM
Dr Evil   Oh, you need to read this site tonight: http://mem...   May 17 2007, 11:38 PM
BahnBrenner914   Ok, so I just tested the ohms on the CHT. I had to...   May 18 2007, 04:48 PM
Dr Evil   :thumbsup: Sounds like CHT is good. Hunting usualy...   May 18 2007, 04:57 PM
BahnBrenner914   Yeah, I had the charcoal canister off when I was t...   May 18 2007, 05:11 PM
Dr Evil   Must be a 76 thing. In the other cars its on top o...   May 18 2007, 07:32 PM
BahnBrenner914   So after it warmed up in the driveway, I took the ...   May 18 2007, 07:40 PM
r_towle   The AAR valve can be removed. I put a plug in the ...   May 18 2007, 10:43 PM
r_towle   Oh, not sure how you are testing the AAR using Ohm...   May 18 2007, 10:44 PM
BahnBrenner914   True, I have the AAR out right now soaking to see ...   May 18 2007, 11:14 PM
r_towle   how does the throttle body look? Is it clean insid...   May 18 2007, 11:28 PM
Dr Evil   Remember, if you had the engine adjusted to run wi...   May 19 2007, 01:11 AM
BahnBrenner914   I adjusted the idle some when I first started mess...   May 19 2007, 01:59 AM
Dr Evil   The AAR is realy inconsequential as it is supposed...   May 19 2007, 09:27 AM
BahnBrenner914   Well I have a 2.0, so not so easy as the 1.8 in th...   May 19 2007, 02:09 PM
Dr Evil   Ya didnt read the whole thing dija :rolleyes: Her...   May 19 2007, 02:18 PM
BahnBrenner914   Ok OK, I got the template. It seems my fan doesnt ...   May 19 2007, 03:34 PM
Dr Evil   Fans are completely interchangable so loss of timi...   May 19 2007, 03:49 PM
BahnBrenner914   Alright, I finally found the timing mark after fin...   May 19 2007, 06:38 PM
SirAndy   So I took it out for a spin and I still have litt...   May 19 2007, 06:44 PM
BahnBrenner914   OK, here's the pics of the engine:   May 19 2007, 07:20 PM
BahnBrenner914   and the driver side:   May 19 2007, 07:21 PM
Dr Evil   You still hae the air injector pipes in the heads ...   May 19 2007, 07:38 PM
BahnBrenner914   You still hae the air injector pipes in the heads...   May 20 2007, 01:26 PM
Bleyseng   you should get Dave Hunt to look at the car as he ...   May 20 2007, 01:46 PM
Dr Evil   CSV is Cold Start Valve. It is the injector that i...   May 20 2007, 01:51 PM
BahnBrenner914   Looking at your picks it seems that it may be a n...   May 21 2007, 06:07 PM
Dr Evil   Looking at your picks it seems that it may be a ...   May 21 2007, 06:33 PM
Pat Garvey   I've been watching this thread, and am amazed ...   May 21 2007, 09:01 PM
Dr Evil   Aw Pat :hugme: This is how it used to be around ...   May 21 2007, 09:23 PM
BahnBrenner914   Well there's several reasons for my 'stick...   May 21 2007, 11:44 PM
McMark   Did you ever replace the gas? If you've got o...   May 22 2007, 12:35 AM
tdgray   I'd be interested in what your plugs look like...   May 22 2007, 09:41 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 10:11 AM
