> Gas tank and AN fittings, Can it be this easy?
Phoenix-MN
post May 19 2007, 06:14 PM
I was working on getting my fuel tank, fuel pump, and lines intalled today and I have been trying to figure out how to adapt the tank fittings to AN. After getting the tank on the bench and removing the stock fittings and tubes it looked like a 1/4npt pipe thread fitting might fit in the opening of the stock fitting. I dug out my taps and low and behold the 1/4npt tap threaded the hole in the stock fitting quite nicely. Could it realy be this easy? What am I missing? Anyone else done it this way?
andys
post May 19 2007, 11:38 PM
Paul,
The tap drill size for a 1/4NPT is 7/16" (.4375). What is the inside diameter of the tank fitting? Were you able to get reasonably full thread form?
Your method greatly simplifies the challenge of plumbing to the tank. I applaud your thinking out-of-the-box! I'll drag my tank out maybe tomorrow and take a look. I know I have some -6 in aluminum, but I too would prefer steel for this application.
Andys
Phoenix-MN   Gas tank and AN fittings   May 19 2007, 06:14 PM
John   That could work, but you may run into clearance is...   May 19 2007, 07:04 PM
Phoenix-MN   Here is a comparison of the stock tubes and 90deg....   May 19 2007, 07:27 PM
John   Looks good to me. Like I said, just make sure it ...   May 19 2007, 08:15 PM
rjames   You'll have plenty of room under the tank with...   May 19 2007, 08:25 PM
Phoenix-MN   John, The aluminum -6AN to 1/4npt fittings are one...   May 19 2007, 08:35 PM
Gint   Keep this thread updated please! I'm dyin...   May 19 2007, 09:18 PM
John   Keep this thread updated please! I'm dyi...   May 19 2007, 09:41 PM
sixnotfour   It would be great to have an elevated pickup tube,...   May 19 2007, 09:36 PM
Phoenix-MN   Yes, the inside of the tank fitting was threaded w...   May 19 2007, 10:02 PM
andys   Paul, The tap drill size for a 1/4NPT is 7/16...   May 19 2007, 11:38 PM
Phoenix-MN   andys, The id. of the stock fittings is a little ...   May 20 2007, 07:54 AM
rick 918-S   You may want to use a sealant on the threads. I wo...   May 20 2007, 09:25 AM
JB 914   You may want to use a sealant on the threads. I w...   May 20 2007, 10:39 AM
JB 914   another thougth would be to use POR PATCH which is...   May 20 2007, 11:09 AM
turbo914v8   I have done this mod and it works great. I just us...   May 20 2007, 02:10 PM
Cap'n Krusty   By the looks of what little of the inside of your ...   May 22 2007, 03:48 PM
Phoenix-MN   Yup, the inside of the tank is nasty. I found a l...   May 29 2007, 07:23 AM
Phoenix-MN   Update - I installed Tangerine Racing SS fuel line...   Jun 30 2007, 11:42 AM
neo914-6   Update - I installed Tangerine Racing SS fuel lin...   Jun 30 2007, 04:30 PM
Phoenix-MN   'nother   Jun 30 2007, 11:46 AM
Phoenix-MN   Update - I installed Tangerine Racing SS fuel li...   Jun 30 2007, 06:34 PM
neo914-6   Where did you get the grommets? Any tips on ins...   Jun 30 2007, 10:04 PM
iamchappy   My god Paul, you've got to get a life! I ...   Jun 30 2007, 07:22 PM
Phoenix-MN   My god Paul, you've got to get a life! I...   Jun 30 2007, 08:10 PM
iamchappy   Ok stranger, I will make a visit soon..... I have...   Jun 30 2007, 09:10 PM
iamchappy   Paul im a little nuts too, when i saw that Devcon ...   Jun 30 2007, 10:08 PM
Phoenix-MN   [quote name='Phoenix-MN' post='918017' date=...   Jul 1 2007, 08:43 AM
neo914-6   [quote name='Phoenix-MN' post='918017' date...   Jul 1 2007, 12:07 PM
andys   I wanted to keep the thread alive since I'm st...   Jul 18 2007, 02:12 PM
Phoenix-MN   Andys, I haven't put the tank in the car yet b...   Jul 18 2007, 02:32 PM
Phoenix-MN   Here's how I did a filter screen. Steel AN fit...   Jul 19 2007, 07:51 PM
Phoenix-MN   Next - silver soldered the tube to the AN fitting...   Jul 19 2007, 07:55 PM
Phoenix-MN   Finally - Soldered the wire tube to the brass and ...   Jul 19 2007, 07:59 PM
retrofit   Finally - Soldered the wire tube to the brass and...   Jul 20 2007, 12:13 AM
iamchappy   Nice job Paul, you always amaze me....   Jul 19 2007, 10:59 PM
iamchappy   Nice job Paul, you always amaze me....   Jul 19 2007, 11:01 PM
skline   That is very impressive, can you make another one ...   Jul 19 2007, 11:10 PM
andys   Paul, Nice job. What mesh is the screen? Also, ...   Jul 19 2007, 11:20 PM
Phoenix-MN   skline, Sorry, I really don't want to get into...   Jul 20 2007, 07:30 AM
jsteele22   I'm using both the socketless hose and braide...   Jul 20 2007, 01:39 PM
Phoenix-MN   Hi-jacking my own thread <_< Chappy, are ...   Jul 20 2007, 07:52 AM
Phoenix-MN   The socketless stuff does take a little "grun...   Jul 20 2007, 01:45 PM
andys   The socketless stuff does take a little "gru...   Jul 20 2007, 03:46 PM
jsteele22   [quote name='Phoenix-MN' post='926069' date=...   Jul 20 2007, 04:02 PM
Phoenix-MN   Boy, it's a good thing we're not talking a...   Jul 20 2007, 06:42 PM
kconway   Bumpin this...wondering if there is any more to ad...   Apr 7 2011, 11:46 PM
jim912928   CB Performance (VW shop) sells AN 6 tank adapters ...   Apr 8 2011, 06:43 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 02:31 PM
