Smoke on Startup, 3.0 CIS six |
brilliantrot |
May 15 2007, 08:37 PM
Member Group: Members Posts: 125 Joined: 27-April 07 From: Costa Mesa Ca. Member No.: 7,699 |
My dad is uprgading from his 912E to a 75 911s with a CIS 3.0 as an autocross car. He is doing this because he is tired of loosing to my 914 and because he cant mod the 912E due to Smog because it is a 76. My question is the motor puffs a rather large cloud of smoke out the exaust on startup concistantly hot or cold but has a totally clean exhaust while running and reving. What would cause this? the motor is supose to have about 30K on it and AASE Motors verifies that the wear on the engine looks to be about this milege while they were replacing the head studs. The only thing that i can come up with is that when the motor is not running some of the 11 plus quarts of oil sitting above the engine runs back filling up the bottom of the engine up to the pistons with some oil leaking past the rings. Is this possible? It makes sence to me because the oil tank gadge goes up (reads more oil) once the engine is started and the massive scavenge pump kicks in. Have any of you 914-6 guys experienced this? Would moving the oil tank to the front solve this? My dad is realy bumbed about this smoke because this engine alone costs more than the entire 912E. Makes one realy appriciate the simplicity and reliability of the T4. I do not know if it makes a difference or not but it is baised on a 3.2 case with the Carrera pump.
rfuerst911sc |
May 22 2007, 05:06 PM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
You can also play around with different brands of motor oil. I have found on my 83SC with 3.0 some oils just seem to smoke a little more than others. No oil will eliminate the smoke but may make it less noticable. Also try 15w-40 and 20w-50. I use 15w-40 Shell Rotella dino oil currently but with it geting hotter here in Orlando I may switch to 20w-50. Mine puffs a cloud if it has sat for 3-4 days. Go run it hard!!
Lo-Fi Version | Time is now: 2nd June 2024 - 03:58 AM |
