> 1987 Carrera Front Calipers
dflesburg
post May 25 2007, 01:19 PM
Why are there two sets of brake lines comming off my 1987 Carrera front Calipers? One is obviously the right one to connect the other is forward of the the correct one and goes to what?
flesburg
post May 25 2007, 06:42 PM
Duane,
You need to send a picture.
If you have turbo calipers there is brake line that goes between the two half's. but only one feed line and then one bleeder on each half.
The carrera calipers should have only one feed line.
Are you looking at the bleeder? and if the PO removed the bleeder plug then you may
have two tapped holes, but one would be the feed line and the other is the bleeder. The bleeder is on the top and the feed line is on the back about in the middle, lined up with the piston.
So, attach a picture and John or I will get back to you.
- Lo-Fi Version Time is now: 15th April 2026 - 11:13 AM
