mabry123 |
Newbie ![]() Group: Members Posts: 14 Joined: 7-December 06 From: Hickory, NC Member No.: 7,331 ![]() |
I found this '76 sitting in the rear lot of a local garage. Owner disappeared, and the mechanic has filed a mechanic's lien against the title. I can get it for a couple hundred bucks.
The mechanic hasn't done anything to it other than try to start it about a year ago. It came there for exhaust work after it was painted in '05, and the owner abandoned it. The body looks solid. The doors close solidly, the rocker panels pass the screwdriver poke test, as does the driver's floorboard, trunk floor and floor under the front hood. The rust on the driver's floorboard appears to be surface -- I went at it hard with a screwdriver, and the metal was solid under the surface oxidation. The paint job is passable, and the interior is mostly just dirty. Well, fithly actually. New window seals and seat inserts needed, it would be passable without. I read through all the receipts in a box in the trunk, and it was all routine maintenance -- valves, oil, seal here and there, new clutch in '02. Are all '76 models 2.0? Which version of FI is typical on a '76 2.0? One of the more recent receipts says "Advised owner of engine oil leak and bad exhaust." But nothing earth-shattering from a quick read through the paperwork. What do you guys think? You've seen way more of these than I have. This one looks a lot better to start than some of the progress threads I've been following. Couple questions -- Can I tow it home with a dolly? Not sure the front dam will clear the dolly ramp, and the wheel bearings might be questionable. Moving it less than 10 miles. What could I expect to spend on a new exhaust system? I realize this is a loaded question, but where should I look first for the engine oil leak? I think I'm going to go for it. I have room in the garage and I'm sure you guys will be behind me all the way. Anybody close to Hickory, NC in case I get in a fix? I have pictures to add, but can't find the "Browse" button the FAQ said to use to add pictures. . Somebody tell me how and I'll put up some photos I took this mornng. |
skline |
Born to Drive ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California ![]() |
I like the trailer hitch on it, you could pull around a cool little trailer with all your stuff in it for 914 runs! Or a trailer made from the back of another 914 that opens to make a BBQ. All kind of ideas come in to my head. (IMG:style_emoticons/default/smile.gif)
Yes, all 1976 models were 2.0 liters. They used D-Jet injection. |
mabry123 |
Lo-Fi Version | Time is now: 3rd July 2025 - 12:00 AM |
