tyler |
Member ![]() ![]() Group: Members Posts: 335 Joined: 24-September 03 From: southern california Member No.: 1,192 ![]() |
I bought a complete front suspension that was supposed to be an '84 Carrera but checking the rotor thickness it appears to be a ~1980 911s. But regardless it has 3 1/2" caliber spacing. I plan to keep my steering box & crossmember and probably sell off the aluminum one. I've got it all cleaned up and painted and have a few questions. Also I'd like to know what problems I might run into and if anyone has any tips.
What I'm curious about now is; 1. Where do the wheels end up compared to the 914? I do have flares. 2. I notice the lug studs are really long and look like they'll have to be cut off. 3. The torsion bars are marked L & R but is there a front & rear? are the splines of the 911 the same as the 914-4 and the adjusters the same? 4. Are the tie rod ands the same (I plan to buy new ones)? 5. Any difficulties rebuilding the calibers? Appreciate any voice of experience. |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,542 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California ![]() |
I bought a complete front suspension that was supposed to be an '84 Carrera but checking the rotor thickness it appears to be a ~1980 911s. But regardless it has 3 1/2" caliber spacing. I plan to keep my steering box & crossmember and probably sell off the aluminum one. I've got it all cleaned up and painted and have a few questions. Also I'd like to know what problems I might run into and if anyone has any tips. What I'm curious about now is; 1. Where do the wheels end up compared to the 914? I do have flares. 2. I notice the lug studs are really long and look like they'll have to be cut off. 3. The torsion bars are marked L & R but is there a front & rear? are the splines of the 911 the same as the 914-4 and the adjusters the same? 4. Are the tie rod ands the same (I plan to buy new ones)? 5. Any difficulties rebuilding the calibers? Appreciate any voice of experience. 1. a arms are the same length. different internal splines than a 914. wheels will end up in same place. 2. if you have longer studs, i will trade you some shorter ones in trade. 3. Torsion bars are a different spline than a 914. stock vs stock = 17.8mm vs 19mm. 911 are slighlty beefier. 4. Buy 930 tie rods. they eliminate the rubber bushings, and give you a more precise feel, vs a squishy feel. they us ball and socket inner joints vs u joint style. 5. calipers are easy. peace of mind - write the check and send em to eric shea. |
Lo-Fi Version | Time is now: 1st August 2025 - 04:45 PM |
