> Starter is dying...replace w/ 911 unit?, $100 more than a teener unit!
Air_Cooled_Nut
post May 31 2007, 11:17 AM
914 Ronin - 914 owner who lost his 914club.com
Starter works fine when cold. After a some driving, to where the starter gets heat soak, it will crank the engine VERY slowly as if the battery is very low on charge. Acts the same exact way while jump starting. But if I let the car cool down for awhile then it will crank like normal. I even had AAA come out and check the battery and charging system with their uber-cool, $600 hand-held analyzer and everything checked out 100%. So I know my battery (Optima) is in tip-top shape and my alternator is just as good.
I've read the hot-start relay threads and understand them. It's a band-aide for a failing starter as well as a safe-guard for the ignition switch. I may do it, I may not. Not sure. But I do know I need a starter. So, GPR has rebuilt Bosch units for the 911 @ $219 and 914 @ $112. Money is tight for me but I'd rather pay once than twice (IMG:style_emoticons/default/wink.gif)
I want to understand WHY the 911 starter is the prefered unit for replacement. I know it has more cranking power but is it at the same voltage/amperage draw as a 914 unit or more? Does the extra power spin the flywheel faster, resulting in a faster start? (IMG:style_emoticons/default/confused24.gif)
Ferg
post May 31 2007, 12:17 PM
I have never heard of anyone having a hot start issue with a high torque starter. I can't say the same for rebuilt or new OEM starters
Ferg
Air_Cooled_Nut   Starter is dying...replace w/ 911 unit?   May 31 2007, 11:17 AM
SirAndy   i got a aftermarket high-torque starter and never ...   May 31 2007, 11:20 AM
Ferg   I agree with Andy :agree: Ferg   May 31 2007, 11:21 AM
Air_Cooled_Nut   Ok, but you're not telling me WHY a higher tor...   May 31 2007, 11:22 AM
SirAndy   Ok, but you're not telling me WHY a higher to...   May 31 2007, 12:01 PM
pin31   :agree: smaller, lighter, more torque (more power...   May 31 2007, 11:26 AM
Vacca Rabite   I have one of the hi torque starters as well, but ...   May 31 2007, 11:29 AM
Ferg   I have never heard of anyone having a hot start is...   May 31 2007, 12:17 PM
McMark   The IMI starter is cheaper and BRAND NEW. The Bos...   May 31 2007, 12:21 PM
Vacca Rabite   :agree: All the above. Also, the new Hi torque ...   May 31 2007, 01:26 PM
Grimstead   Here you go, this is where I bought mine... eBay ...   May 31 2007, 02:48 PM
Air_Cooled_Nut   Here you go, this is where I bought mine... eBay...   Jun 1 2007, 12:40 PM
Trevorg7   I have never heard of anyone having a hot start i...   May 31 2007, 03:15 PM
Rand   Good unit. "Hot start" issues are anot...   May 31 2007, 03:42 PM
McMark   :agree: A solid ground strap, and good battery cab...   May 31 2007, 04:55 PM
ConeDodger   :agree: A solid ground strap, and good battery ca...   May 31 2007, 05:29 PM
scotty b   I asked this once before when this subject came up...   May 31 2007, 06:59 PM
PinetreePorsche   B)-->
- Lo-Fi Version Time is now: 2nd April 2026 - 07:55 PM
