| bondo |
Jun 3 2007, 04:35 PM
Practicing my perpendicular parking ![]() ![]() ![]() ![]() Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
I've got a 1970 914, and the splines on the wiper motor shafts were hosed. I installed a later wiper motor, (well, jkeyzer did it) and expected it to work. The terminals arranged the same, and it LOOKS like it's a straight swap.
The early switch supplies power in the off position on a green wire with white stripe. This goes to pin 31b of the wiper motor. This appears to be for the purpose of parking the wipers after the switch is turned off. On the early motor, this wire goes into the third terminal of the wiper's internal rotary switch. The late motor still has 3 terminals on its internal switch, but the third one is not used, and terminal 31b goes to the second terminal. The unused terminal is grounded to the case. I opened up a spare late motor, and found that the internal switch grounds pin 31b. Grounding a hot wire of course leads to fuse blowage. Does anyone know a way I can rewire this late motor to an early car, so I can use it? Here's the catch. The fresh air box and gas tank are already in, and the tank has gas in it. I'd REALLY like to figure out a way to rearrange the wiring at the motor and/or the switch that doesn't involve removing the motor. (IMG:style_emoticons/default/smile.gif) I've looked at early/late wiring diagrams, and so far all I've done is give myself a headache. The car is a 70, and the motor is unknown, but clearly different. |
JPB Thats cool, good news and thank God foe fuses. It... Jun 3 2007, 04:43 PM
bondo Ok, got it figured out. I had it wrong, the switch... Jun 3 2007, 05:36 PM
geniusanthony I am in the same situation, I replaced my early 71... Dec 30 2009, 07:24 AM
geniusanthony I took some time to figure out the motors and why ... Jan 1 2010, 05:01 PM
geniusanthony I would hazard a guess that the contacts are the s... Jan 1 2010, 05:06 PM
geniusanthony What the diagram shows:
Chassis to wiper spade lug... Jan 1 2010, 05:25 PM
Travis Neff Who the hell are you? :poke: :D Jan 1 2010, 05:48 PM
geniusanthony So yah, I may have fallen off the "world... Jan 1 2010, 08:37 PM
HalfMoon Hmm. Well I'm experiencing a slightly differen... Sep 19 2013, 05:34 PM
bulitt Make sure you have the wires on correctly
Pics of ... Sep 19 2013, 07:40 PM
HalfMoon
Pics of... Sep 20 2013, 06:50 AM![]() ![]() |
Lo-Fi Version | Time is now: 19th November 2026 - 06:26 PM |
