Engine Clatter, New rebuild and Cam |
2-OH! |
Jun 11 2007, 01:59 PM
Senior Member Group: Members Posts: 552 Joined: 17-October 03 From: Santa Clarita, Kalifornication Member No.: 1,253 |
When we rebuilt the 73 1.7, I wanted to re-use the D-Jet so we put just the next step up from stock, Web Cam and lifters in the motor...
I have advanced the timing just a little to get rid of the clatter but it's still there if I really get on it... Should I continue to advance the timing or should I retard it ??? Already using 92 octane... 2-OH! |
Cap'n Krusty |
Jun 11 2007, 02:32 PM
Web Cam's "next step up from stock" does NOT work satisfactorily in the "real world", despite what the salesman is telling you. Recalibrating the MPS provides a small improvement in drivability, but you still have large HC numbers at the tailpipe. HCs are unburned fuel. No amount of fiddling is going to get rid of the "tip in" performance problem off idle. The ONLY aftermarket "performance" cam about which I've heard good things in actual use with Bosch EFI is Jake Raby's cam, but I have no personal experience with it.
As for your noise, advancing the timing is going to promote detonation, as well as causing a heat problem that's invariably fatal to air cooled engines. You ned to properly adjust the valves, set the point dwell and timing to specs, and see what happens. Other sources of clatter are sloppy piston fit, improper backlash in the cam gear, the gear coming loose on the cam, the bolts hitting the oil pump, rods with too much side play, loose wrist pin bushings, and a host of other things. The Cap'n |
Lo-Fi Version | Time is now: 2nd June 2024 - 07:18 AM |
