Stripped for paint |
watsonrx13 |
Apr 14 2007, 08:34 PM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
Well, I finally finished prepping the car for paint. I have a local painter that has agreed to paint my car, so to save money he requested that I strip the paint down to metal. He'll do the minor body work, primer, base-coat, clear-coat. I'm suppose to take it by tomorrow (Sunday), but I'll have wait until the front passes by.
It taken me about 40 hrs to remove all of the paint. I started after work last Thursday, all day Friday (Good friday holiday), Saturday, Sunday and today. This is the only body repair needed. It had about 1/2" of bondo at the deepest. It took me 5 hrs to strip this door. There's also some body work to be done on the rear quarter panel. After stripping I used Ospho to protect the metal, then painted a light coat of etch primer, per the painter's requirements... Here's why it's taken me so long to strip the car, I didn't have a large enough air tank to run the DA, so I strip everything with this electric hand drill with 3M purple sanding discs. For the next teener to be painted, I'm going to buy an electric DA sander.... Here's an in process shot... After spending 10 hrs today finishing the stripping I forgot to take any pictures of the completely naked teener.... I'll take pics before I drop it off at the painters.... BTW, I'm enjoying several nice Black-n-Tan beers today and tomorrow and looking forward to doing NO WORK on the teener tomorrow... -- Rob |
djm914-6 |
Jun 13 2007, 04:14 PM
Happiness is: Getting on the road Group: Members Posts: 1,864 Joined: 6-February 03 From: Burlington MA Member No.: 248 Region Association: None |
Once the body is stripped, do you need to prime it imediately? What about flash rust? When I took one fender down to metal, it started to hase over within a few hours.
watsonrx13 |
Jun 13 2007, 05:01 PM
Once the body is stripped, do you need to prime it imediately? What about flash rust? When I took one fender down to metal, it started to hase over within a few hours. DJM, once you expose the metal to air it will flash rust, the higher the humidity, the greater/quicker the rust. I've used Ospho on the bare metal and it has helped keep the flash rust under control here in central FL for about 2 weeks. But, I recommend that the etch primer be put on the exposed metal as soon as possible... Thanks guys for the compliments... (IMG:style_emoticons/default/biggrin.gif) -- Rob |
djm914-6 |
Jun 14 2007, 07:47 AM
DJM, once you expose the metal to air it will flash rust, the higher the humidity, the greater/quicker the rust. I've used Ospho on the bare metal and it has helped keep the flash rust under control here in central FL for about 2 weeks. But, I recommend that the etch primer be put on the exposed metal as soon as possible... -- Rob Thank you! I'm enjoying this thread. You've done a great job. |
Lo-Fi Version | Time is now: 2nd June 2024 - 04:39 AM |
