Weber Help, RAT 2056 |
HalM |
Jul 4 2007, 07:31 AM
Green Skull 003 Group: Members Posts: 127 Joined: 19-January 05 From: The 'Burg Member No.: 3,472 Region Association: None |
I ran a DE this past weekend. It seemed that with each session, idle became a bit rougher and slower. By the end of the day, a few friends said it sounded like I was running on 3 cylinders coming back into the paddock. I suspect a dirty fuel filter and /or clogged idle jets. WOT was pretty reasonable.
Where are the idle jets on these carbs? Do I need to pull the top half off to get to them? If so, do I need a need gasket to reassemble? I have no idea if they have even been split and Jake built the motor about 4 years ago. Thanks and any help. Hal |
IronHillRestorations |
Jul 4 2007, 10:28 AM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
One thing you can do is to get the car up to operating temp and then back out the idle jet carrier about a half to one full turn. If the engine stumbles then that jet is probably working OK, if nothing happens then that jet or the idle jet passage is probably clogged.
Lo-Fi Version | Time is now: 11th June 2024 - 12:00 AM |
