Fuel: Pre-filter? |
Fuel: Pre-filter? |
Danny_Ocean |
Jul 3 2007, 12:55 AM
Member Group: Members Posts: 170 Joined: 27-June 07 From: Fort Lauderdale, FL Member No.: 7,846 Region Association: South East States |
914-6 w/2.4 '72 911 "T" motor, MFI
The previous owner of my car (let's call him "Bubba") installed a regular plastic in-line fuel filter between the tank and the fuel pump. The factory fuel filter is upstream (between fuel pump and injector pump). Is this "pre-filter" necessary? Looks like one big fuel leak waiting to happen. (IMG:style_emoticons/default/blink.gif) |
Cap'n Krusty |
Jul 4 2007, 03:17 PM
For stock applications, I recommend (and use) a metal filter from a 2002 Tii (13 32 1 256 492, or Bosch # 71 015). 8mm inlet and outlet. You should also have the special 10mm>7mm adapter hose from the plastic line to the filter (914 356 525 00). A bit costly, but it FITS. Spend a little money here, and you'll lessen the frequency of changes of the astronomically expensive MFI filter. The Cap'n
Danny_Ocean |
Jul 4 2007, 04:11 PM
For stock applications, I recommend (and use) a metal filter from a 2002 Tii (13 32 1 256 492, or Bosch # 71 015). 8mm inlet and outlet. You should also have the special 10mm>7mm adapter hose from the plastic line to the filter (914 356 525 00). A bit costly, but it FITS. Spend a little money here, and you'll lessen the frequency of changes of the astronomically expensive MFI filter. The Cap'n Where does this adapter hose fit into the system? Again, I have a 2.4 MFI system, including the fuel pump. The hoses appear to all be the same size where they come through the firewall (from the tunnel) and go to the pump. I'm not sure where the size reduction is. Yes, the MFI filter is $59... (IMG:style_emoticons/default/sad.gif) |
Lo-Fi Version | Time is now: 9th June 2024 - 01:41 AM |
