Tach/engine jumping up and down... help please |
tod914 |
Jul 8 2007, 11:20 AM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
Just started happening. The car is a 75 2.0 with fuel injection. It has a pertronix ignition. The problem is, it seems to be jumping up and down in the rmp's and idles very low. Idle adjustment didnt seem to help. I checked all the grounds and contacts including the tranny strap. I swapped out the voltage reg and throttle switch and the problem still persisted.
Computer problem? Timeing problem? timeing was done last year, fi trigger points a few years old. Pertronix problem? its about 4 years old Bad coil? 4 years old Grounding issue? has new fi harness from bowsby - 2 years old Head temp sensor? its about 2 years old. What would you all suggest. Thanks for the help, Tod |
tod914 |
Jul 8 2007, 07:10 PM
Ok guys thanks for the tips.. I'll order some points and a condensor, and check all the fuzes. I try the original distrib to rule out bad bushings on the current one. I'll see when I can get the valves done as well, I think they only have about 1000 miles or so since the last adjustment. Btw is it easy to replace the Distributor Contact Breaker Plate? The original is alittle corroded.
Lo-Fi Version | Time is now: 8th June 2024 - 02:35 PM |
