> Model Specific Information
> Washing a 914, Pat's dry method?
swm914
post May 1 2007, 11:34 AM
This seems like a dumb question but how do you wash a 914?
Pat mentioned in the topic on waxing that he hasn't washed his car in 6 years. It raised the question in my mind. Is that best and normal for 914's?
Since I bought my 914 in December it hasn't been washed. Since I've learned more about them since then (stuff like "there is nothing like a rust free 914" etc.) I've been afraid to wash the thing. It'll be a "fun" car, (maybe a few "fun" shows along the way)and garaged all the time but even now, after a few nice spins, it needs washed.
So, I'll ask Pat to elaborate on his dry method. Also, any other practical tips from other long time 914 owners would be appreciated. Thanks
Steve
tod914
post Jul 10 2007, 10:47 PM
When I dry mine, I always pull off the front and rear trunk seals and make sure the trunk gutters are throughly dried with a towel. I'll also take a paper towel and run the edges inside the window trim to absorb any water. water also gets trapped in the black plastic vent plugs in the door jams, be sure to try that area out as well.. the compressed air method sounds like a good way to go (IMG:style_emoticons/default/smile.gif)
I also but a blanket in the engine bay so no water gets in there through the grills when i rinse it.
Steve how's your GT comming along? Have you had a chance to post any pictures of the restoration yet?
orthobiz
post Jul 11 2007, 08:59 PM
QUOTE(tod914 @ Jul 11 2007, 12:47 AM) *
I've heard of this but my front trunk rubber is glued in place (factory style, I'm sure). Should I pull it up and un-glue it?
Paul
Pat Garvey
post Jul 11 2007, 09:25 PM
Do I or don't I...........?
QUOTE(orthobiz @ Jul 11 2007, 08:59 PM) *
Paul
NO! Don't pull it loose from the glue. You'll only make matters worse.
If you MUST flood your 914 with water:
Front trunk - water drains from the top to the bottom corners. Carefully lift the rubber near the headlight areas (just enough to NOT break the glue bond). Cram in the "corner of a shop towel" (not regular paper towels, as they aren't as absorbent). Let the towel absorb the excess water for a couple of hours, until nothing else seems to be being absorbed. Pull it out & put another in - you'll be surprised at what else comes out. These channels are an expensive bitch to replace - protect them.
Rear trunk - pull the seal off, it's not held on with glue. But, there is a channel inside the seal & it has metal binding embedded in it. Run towels inside the seal edges to get any water out, else it will eventually get to the metal inside the seal & ruin it. Blowing it out with air pressure is a good idea too, though you can't get all of it out.
Sorry if I seem to be harping here, but (except in extreme circumstances) you do not need to flood your 914 with water to clean it. It takes about 20 minutes to "dry wash" a 914, and walk away.
Pat
swm914   Washing a 914   May 1 2007, 11:34 AM
Pat Garvey   This seems like a dumb question but how do you wa...   May 1 2007, 09:29 PM
swm914   Pat, Thanks for sharing your method of washing Fr...   May 2 2007, 05:19 PM
sendjonathanmail   so, dont hose it off???   May 2 2007, 06:38 PM
Pat Garvey   so, dont hose it off??? Do what's convenient...   May 2 2007, 08:49 PM
orthobiz   Nice ideas, Pat. I'm an orthopaedic surgeon fo...   May 3 2007, 06:59 PM
Pat Garvey   Nice ideas, Pat. I'm an orthopaedic surgeon f...   May 3 2007, 07:13 PM
smg914   Although I only washed my car once since the 2003 ...   May 5 2007, 11:16 PM
sendjonathanmail   that actually sounds like a good idea... is there ...   May 6 2007, 08:04 AM
Thomas J Bliznik   HI Guys, Sure do learn a lot about you guys on th...   May 6 2007, 08:41 AM
dflesburg   Y'all need to be drug tested.... Good Grief.   Jul 10 2007, 02:51 PM
Pat Garvey   Y'all need to be drug tested.... Good Grief....   Jul 10 2007, 09:11 PM
tod914   When I dry mine, I always pull off the front and r...   Jul 10 2007, 10:47 PM
orthobiz   When I dry mine, I always pull off the front and ...   Jul 11 2007, 08:59 PM
Pat Garvey   When I dry mine, I always pull off the front and...   Jul 11 2007, 09:25 PM
smg914   Steve how's your GT comming along? Have you h...   Jul 13 2007, 11:43 PM
Johny Blackstain   :drooley: :shades:   Jul 13 2007, 11:56 PM
tod914   Im not crazy about the idea of the front trunk sea...   Jul 11 2007, 11:40 PM
sendjonathanmail   so, your front trunk seal isnt glued in? sounds ...   Jul 12 2007, 04:08 PM
Johny Blackstain   This is where the rust exists on my six (right sid...   Jul 12 2007, 04:35 PM
stevesc_us   I have owned my original six for 15 years. Over t...   Jul 12 2007, 06:39 PM
Pat Garvey   I have owned my original six for 15 years. Over ...   Jul 12 2007, 06:56 PM
tod914   Beautiful... it needs paint?? Looks fantastic in t...   Jul 14 2007, 12:38 AM
- Lo-Fi Version Time is now: 19th July 2025 - 09:01 AM
