> Front end neg camber, how much have you got, how'd ya get it
ottox914
post Jul 11 2007, 10:47 PM
The glory that once was.
Looking for some inside secrets, black magic, motorhead mojo, on front end camber. I know our cars are a mixed bag in terms of what you can get in front. My '73 with the GPR/tarrott camber plates can get 2.4 neg on one side, only 1.8 on the other. The chassis measures out fine, no tweekage. It'd by nice to be able to equalize them both at around 2.5, or better still, 3.0, but how. I have no interest in taking this car to autocross nationals or get into hard core scca auto x stuff, just want to putter around and make a better local car, so bending the rules a little doesn't scare me, depending on how far the bend is.
So what do you all have, and how'd you get it?
Anyone use an aftermarket bolt on camberplate like all the little ricer guys run? I've never seen one for our cars, but they don't look hard to make. I was wondering if one could be designed to hold the top strut bearing up over the plate, thus allowing: 1) a little more strut travel on lowered cars, and 2) if the bearing is up over the adjustable top plate, the strut could maybe "tip" more to the inside, as the slim diameter of the strut rod would be smaller than the bearing or strut tube, and could be tilted in, closer to the edge of the factory hole.
I'm picturing something like this: http://cgi.ebay.com/ebaymotors/Steeda-Cast...1QQcmdZViewItem
J P Stein
post Jul 13 2007, 06:48 PM
Irrelevant old fart
By all means, get more negative camber. Brad Roberts says good drivers use lots of negative camber so if you wanna be thought of as good, get -3/-4. You may wear out the iinside edges of your tires quickly, but you'll look cool doing it.(IMG:style_emoticons/default/biggrin.gif)
Borderline
post Jul 14 2007, 09:53 AM
QUOTE(J P Stein @ Jul 13 2007, 04:48 PM) *
As long as I look cool doing it that's all that matters! (IMG:style_emoticons/default/smile.gif) Actually I'd like to like good on the results page too. I remember Brad's posts about the euro drivers using so much camber and going so fast. Gotta be the way to go! (IMG:style_emoticons/default/biggrin.gif)
A recent copy of Grassroots Motorsports profiles a 240sx champion that is running 4.5* neg up front. And Nathan did very well when he was running his teener. I had no idea he was running so much neg camber. The way I see it, the more body roll you have the more neg camber you have to put in to get the tire upright in the corner. Of course, all of this seems to go out the window when you start talking about bias ply slicks.
OK JP, what you running and how'd you get there?
nebreitling
post Jul 14 2007, 01:06 PM
Member Emeritus
QUOTE(Borderline @ Jul 14 2007, 08:53 AM) *
run whatever you need to go fast, regardless of what JP or Brad or anyone says (actually, that's exactly what Brad is saying). for me (running hoosiers/710's), this was -3.5~ish. was about to go for more, but I sold the car. tire temps, wear, and timeslips will always reveal the truth.
yeah, I think of myself as good. not because of freakin' camber.
ottox914   Front end neg camber   Jul 11 2007, 10:47 PM
nebreitling   i got -3.2 LF and -3.5 RF when i had my car. coul...   Jul 11 2007, 11:25 PM
nebreitling   oh, also look for the elephant decambered balljoin...   Jul 11 2007, 11:26 PM
SirAndy   i'm going back to 0 (yes, zero) camber front a...   Jul 12 2007, 12:00 AM
Dan (Almaden Valley)   i'm going back to 0 (yes, zero) camber front ...   Jul 12 2007, 12:59 AM
Joe Ricard   [ Actually slicks like enough camber be it positiv...   Jul 12 2007, 08:32 AM
SirAndy   Actually slicks like enough camber be it positive...   Jul 12 2007, 10:26 AM
ottox914   Not running slicks (yet) so thats not a factor in ...   Jul 12 2007, 07:36 AM
nebreitling   i believe i do remember enlarging the "cent...   Jul 13 2007, 11:15 AM
Borderline   :stromberg: I gotta get me some of that neg cambe...   Jul 12 2007, 10:16 AM
ChrisNPDrider   .... and removing the cover from the shock piston...   Jul 12 2007, 11:52 AM
mskala   I'm also using the tarrett camber plate and go...   Jul 12 2007, 12:08 PM
DownUnderMan   Pull the 1.8 leg out, take out the insert, put in ...   Jul 12 2007, 02:57 PM
Borderline   Pull the 1.8 leg out, take out the insert, put in...   Jul 12 2007, 07:22 PM
Joe Ricard   Yes you have a point about the shock covers up fro...   Jul 12 2007, 04:16 PM
ottox914   Pull the 1.8 leg out, take out the insert, put in...   Jul 12 2007, 06:36 PM
DownUnderMan   The further detail: 1 Remove the strut insert fr...   Jul 12 2007, 09:11 PM
Borderline   It's been a while since I put my konis in the ...   Jul 13 2007, 11:12 AM
DownUnderMan   I should have mentioned that the inserts are Koni ...   Jul 13 2007, 02:24 PM
Borderline   OK that splains it! I'll have to give it ...   Jul 13 2007, 06:37 PM
J P Stein   By all means, get more negative camber. Brad Rober...   Jul 13 2007, 06:48 PM
Borderline   By all means, get more negative camber. Brad Robe...   Jul 14 2007, 09:53 AM
nebreitling   By all means, get more negative camber. Brad Rob...   Jul 14 2007, 01:06 PM
J P Stein   [quote name='Borderline' post='923327' date='Jul ...   Jul 14 2007, 01:57 PM
Joe Ricard   Good luck JP. sounds like Packwood is where the b...   Jul 14 2007, 08:44 PM
J P Stein   Good luck JP. sounds like Packwood is where the ...   Jul 15 2007, 09:48 PM
ottox914   So, seems for DOT R's, more camber is more bet...   Jul 14 2007, 08:53 PM
Dave_Darling   So, seems for DOT R's, more camber is more be...   Jul 15 2007, 10:55 AM
Joe Ricard   This picture show would be interesting. Who wants...   Jul 15 2007, 07:28 AM
Borderline   Hi Dave! I saw that article. They were runni...   Jul 15 2007, 06:44 PM
J P Stein   I use brakes a lot and hard at AX. Your HP may dif...   Jul 15 2007, 09:45 PM
Joe Ricard   That was my job last year. "tire warmer for ...   Jul 16 2007, 11:48 AM
jhadler   Static negative camber is essential for a strut ca...   Jul 16 2007, 06:12 PM
Joe Ricard   Holy crap Josh you been peeking in my race car bo...   Jul 16 2007, 08:47 PM
J P Stein   Odd, I checked my front camber as I pushed it to t...   Jul 16 2007, 10:01 PM
jhadler   Odd, I checked my front camber as I pushed it to ...   Jul 16 2007, 11:24 PM
Dave_Darling   Well, strut suspensions usually gain positive camb...   Jul 16 2007, 11:25 PM
Dave_Darling   Chuck Moreland (of Elephant Racing) posted a very ...   Jul 18 2007, 12:08 AM
Dave_Darling   Chuck assented, so here is his reply on the Bird b...   Jul 18 2007, 09:31 AM
Borderline   Dave: I agree that you get camber with suspension ...   Jul 18 2007, 11:07 AM
Dave_Darling   OK, now drop your car into the weeds so that the A...   Jul 18 2007, 08:54 PM
Borderline   My first attempt to get more negative...my wife sa...   Jul 25 2007, 11:09 AM
jhadler   My first attempt to get more negative...my wife s...   Jul 25 2007, 11:13 AM
ottox914   My first attempt to get more negative...my wife s...   Jul 25 2007, 11:53 AM
Joe Ricard   Ok so I must have a mental block. if you lower the...   Jul 25 2007, 11:47 AM
Joe Ricard   How plyable is that stuff you poured? Just asking ...   Jul 25 2007, 12:48 PM
Borderline   I popped out the stock bushing/rubber grommet and ...   Jul 25 2007, 02:12 PM
jhadler   I popped out the stock bushing/rubber grommet and...   Jul 25 2007, 02:33 PM
Joe Ricard   We use this stuff called "chock fast" Mo...   Jul 25 2007, 04:00 PM
Borderline   The RTV thing is a two component polyurethane that...   Jul 26 2007, 11:08 PM
ottox914   Could you take some metal rod of some sort, and we...   Jul 27 2007, 09:37 PM
Borderline   Looking at my current front camber plates, they ...   Jul 27 2007, 10:18 PM
stownsen914   Could you take some metal rod of some sort, and w...   Jul 28 2007, 05:33 AM
ottox914   [quote name='ottox914' post='928942' date='Jul 27...   Jul 30 2007, 07:40 AM
Borderline   I did a search but couldn't find the thread he...   Jul 30 2007, 11:36 AM
ChrisNPDrider   Bill - I know I said you can have those camber pla...   Jul 30 2007, 01:01 PM
Borderline   Too late Chris they're mine now!! The...   Jul 30 2007, 01:52 PM
ChrisNPDrider   I'm pretty sure that going to 2.5 neg camber i...   Jul 30 2007, 02:15 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 09:25 AM
