> Composite mold making questions
TonyAKAVW
post Jul 16 2007, 01:48 PM
That's my ride.
I want to make a diffuser/engine pan for my car, and last night I started gluing foam sheets together to make a mold. My plan is to form the foam into the shape I want and then seal it with body filler, and then primer and polish. I have been reading up on making molds for composite work and most seem to talk about making a copmosite piece for the mold rather than what I am planning. If I make my mold as described will my composite part rip the mold apart when I seperate the two? (assuming I use a PVA mold release film).
Also, if I make the part with carbon fiber, how do I finish the edges of the piece when I'm done?
I would like to vacuum bag this part because the part will be visible from the top and the bottom... Can I get away not bagging it and get a decent finish? (I'm not super concerned that it has a perfect surface really).
-Tony
Finished part will look something like this...
With the long straight edge meeting up against the firewall and the two tunnels exiting right under the bumper.
TonyAKAVW
post Jul 16 2007, 04:20 PM
That's my ride.
Felix: Not sure about what you mean in terms of what I'm making. The mold that I'm working on should end up looking like this:
Basically its a foam piece (with sealer and primer, etc. on the surface) and then I will layer the cloth on top of that. I will probably use some kind of mat between CF layers to reduce cost, but this large foam piece won't be part of the finished product. The whole foam piece will be glued to a 1/2 inch MDF board. Which in turn will be supoprted by 2x4s. I figure that should help during the vacuum bagging, to prevent mold warpage.
-Tony
okieflyr
post Jul 16 2007, 07:36 PM
9fauxteen
My experience is vacuum bagging 60" composite model sailplane wings panels.
We use mylar for the surface finish which can come out beautiful when doing paint design transfers.(no pinholes)
My suggestion is to bag ALL your individual precut pieces flat, and lay in your spars and predetermined attatchment points within your lay-up.
Then you can assemble the pieces. You may have a hard time getting the bag to conform to your concave 90's and get some flooding. (not the worst place though).
Blue or pink extruded foams work well with the epoxy finishing resins, and there is no sealing requirement, but it won't deal with direct heat well.
Kevin
QUOTE(TonyAKAVW @ Jul 16 2007, 05:20 PM) *
-Tony
TonyAKAVW   Composite mold making questions   Jul 16 2007, 01:48 PM
BahnBrenner914   First of all, SWEET! :woohoo: I'm an ME...   Jul 16 2007, 01:53 PM
john rogers   A couple of questions, do the exhaust headers drop...   Jul 16 2007, 02:04 PM
URY914   Second of all: WHY, To catch the oil?   Jul 16 2007, 02:06 PM
TonyAKAVW   BahnBrenner: If my mold lasts I can make another ...   Jul 16 2007, 02:21 PM
BahnBrenner914   Well I thought you had a stock-type teener, so the...   Jul 16 2007, 02:26 PM
TonyAKAVW   Here's kind of what I anticipate the fitmet to...   Jul 16 2007, 02:34 PM
neo914-6   Tony, Appears you are actually making a part with...   Jul 16 2007, 02:53 PM
TonyAKAVW   Felix: Not sure about what you mean in terms of w...   Jul 16 2007, 04:20 PM
neo914-6   Felix: Not sure about what you mean in terms of ...   Jul 16 2007, 05:12 PM
okieflyr   My experience is vacuum bagging 60" composite...   Jul 16 2007, 07:36 PM
iamchappy   I might be easier to make it out of aluminum or st...   Jul 16 2007, 04:42 PM
GWN7   Chappy's right....it would be easier to make i...   Jul 16 2007, 05:01 PM
JPB   Its not to hard to do Tony. If your mould is smoo...   Jul 16 2007, 05:08 PM
Brando   Get ahold of the pan/diffuser for a 964 or 993 and...   Jul 16 2007, 05:40 PM
TonyAKAVW   From the reading I've done, it seems that 10-1...   Jul 16 2007, 06:13 PM
kwales   I've used plaster of paris before, casts smoot...   Jul 16 2007, 07:38 PM
TonyAKAVW   First of all, thanks for all the tips! I...   Jul 16 2007, 07:50 PM
okieflyr   Unless you are using a very specialized resin, you...   Jul 16 2007, 09:46 PM
GWN7   First of all, thanks for all the tips! I...   Jul 16 2007, 10:08 PM
fat73   First of all, thanks for all the tips! I...   Jul 19 2007, 10:53 PM
kwales   If you are careful (NO FIRE OR FLAMES) , a cardboa...   Jul 16 2007, 07:55 PM
URY914   I've been kicking around bilding one for my ra...   Jul 16 2007, 08:30 PM
URY914   mo   Jul 16 2007, 08:31 PM
URY914   llll   Jul 16 2007, 08:32 PM
tdsmoonchild   just remember that if you make it, and it's co...   Jul 16 2007, 08:34 PM
URY914   On some of them the vertical fins are bolt on not ...   Jul 16 2007, 08:41 PM
iamchappy   These things are way cool. You have a great idea h...   Jul 16 2007, 08:43 PM
TonyAKAVW   Paul: Nice pics! There's a web site (unfo...   Jul 16 2007, 08:45 PM
Joe Ricard   Yup I want one for lapping days and commuting back...   Jul 16 2007, 08:57 PM
TonyAKAVW   So tonight I finished stripping the metallization ...   Jul 17 2007, 01:23 AM
TonyAKAVW   view from the other side.   Jul 17 2007, 01:24 AM
highways   Oh boy, don't burn that foam. No hot knife all...   Jul 17 2007, 02:47 AM
URY914   Tony, If I were you I would make this as easy a...   Jul 17 2007, 08:02 AM
andys   Tony, If I were you I would make this as easy ...   Jul 17 2007, 10:58 AM
TonyAKAVW   Okay, so it sounds like there are a bunch of diffe...   Jul 17 2007, 12:49 PM
geniusanthony   I have also done some composite work on R/C pylon ...   Aug 2 2007, 07:35 AM
TonyAKAVW   Thanks for the tip! I've got to be carefu...   Aug 2 2007, 11:19 AM
geniusanthony   if you do a search and find the sites of Coverite,...   Aug 2 2007, 07:52 PM
- Lo-Fi Version Time is now: 4th July 2025 - 04:32 PM
