#3 cylinder injector quirk, When I pull the lead, nothing happens. |
moneysmarts |
Jul 20 2007, 10:11 AM
Member Group: Members Posts: 164 Joined: 2-March 04 From: Central Massachusetts Member No.: 1,745 Region Association: None |
I thought I had a bad injector on #3. With the motor is running, when I pull the lead to #1, #2, or #4, the engine stumbles as you would expect. If I remove the connector to cylinder 3, however, nothing happens. Even though I was getting a decent spray pattern when I pulled the injector out, I decided to replace the injector. Still nothing. There IS spark at the plug. And my noid light shows that there's electrical pulses at the connector lead. (IMG:style_emoticons/default/blink.gif) On the back of the block, under the air cleaner, I have three pairs of white wires that are solidly grounded.
Any ideas fellas? Thanks |
VaccaRabite |
Jul 20 2007, 11:03 AM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
to make bang, you need spark, fuel, and compression all at the right time.
Does #3 hold compression? Zach |
Lo-Fi Version | Time is now: 8th June 2024 - 06:27 PM |
