> OK guys. I've got a handling question., I've got no experience setting up a mid engined car for taking on
Dr. Roger
post Jul 24 2007, 05:17 PM
A bat out of hell.
Here's where the car stands.
Front:
911 Targa front suspension
22mm Elephant Racing torsion bars
Bilsteins
8X18 Hollow spoke turbo twisties
Almost new Pilot Sports
About 1.5 degrees of camber.
Minimal caster and toe.
No sway bar.
Rear:
Koni Sports set on stiff rebound
150 lb. coils (and no, I'm not going stiffer. I have back problems as it is)
11X18 Hollow spoke turbo twisties
Approximately 2 degrees of camber.
Approximately 0 degree of toe
No sway bar.
I'm finding the car is predictably over-steering with balanced throttle.
Is there a way to adjust either of the suspensions to get a more centered drift and less over-steer given my current setup?
All suggestions are greatly appreciated.
Cheers. (IMG:style_emoticons/default/smile.gif)
Jeffs9146
post Jul 24 2007, 06:48 PM
Ski Bum
3/4" front suspension travel is not enough! Your car is too low for the suspension to properly function. You should consider lowering the spindles if you need it that low!
My .02 cents.
nebreitling
post Jul 24 2007, 08:17 PM
Member Emeritus
QUOTE(Jeffs9146 @ Jul 24 2007, 05:48 PM) *
My .02 cents.
i think (hope!) he's talking about how much bump he can achieve by pushing down by hand -- not total travel. otherwise, he definitely has a problem!
22 Tbars are definitely well on the stiff side for a street car.
Dr. Roger   OK guys. I've got a handling question.   Jul 24 2007, 05:17 PM
nebreitling   install front sway bar. an adjustable 19 or 22mm ...   Jul 24 2007, 06:13 PM
Dr. Roger   That puzzles me. I can barely compress the front ...   Jul 24 2007, 06:20 PM
ChrisNPDrider   :agree: Maybe those underbody 911 types would wor...   Jul 24 2007, 06:23 PM
Andyrew   Predictable over steer with a balanced throttle is...   Jul 24 2007, 06:38 PM
nebreitling   your set-up is a bit unusual (no sway bars, big T-...   Jul 24 2007, 06:45 PM
nebreitling   i don't necessarily agree with Andrew on the r...   Jul 24 2007, 06:48 PM
Dan (Almaden Valley)   i don't necessarily agree with Andrew on the ...   Jul 24 2007, 06:57 PM
Jeffs9146   3/4" front suspension travel is not enough...   Jul 24 2007, 06:48 PM
nebreitling   3/4" front suspension travel is not enough...   Jul 24 2007, 08:17 PM
Andyrew   I was talking about street setups, but hey you guy...   Jul 24 2007, 07:19 PM
dan10101   Roger, Here are a couple charts that may help un...   Jul 24 2007, 09:39 PM
Demick   As to the camber discussion: you normally need mor...   Jul 24 2007, 09:45 PM
Dr. Roger   Wow, I'm glad I asked the question. :thumbs...   Jul 25 2007, 12:34 AM
Dr. Roger   Oh, and Demick, I think 914's have "semi...   Jul 25 2007, 12:38 AM
Dave_Darling   Try softening the rear shocks before you go boltin...   Jul 25 2007, 12:49 AM
Dr. Roger   Thanks Dave, I will loosen my rears shocks a litt...   Jul 25 2007, 01:29 PM
nebreitling   also, your alignment specs are pretty loose. for ...   Jul 25 2007, 01:33 PM
Dr. Roger   Hey Nate, Yes, that's right, I did adjust my ...   Jul 25 2007, 02:15 PM
nebreitling   yikes! w/out commenting on your mbz and maser...   Jul 25 2007, 03:01 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 04:32 PM
