muffler sheild and steering sheild, what is the proper finish |
freezing14 |
Jul 27 2007, 09:52 PM
freezing14 Group: Members Posts: 435 Joined: 21-June 04 From: brockville , Ontario, Canada Member No.: 2,233 |
both good condition but no trac e of the previous fininsh, what is correct for a -6 ,is there a difference with late car or -4
Pat Garvey |
Jul 28 2007, 08:20 PM
Do I or don't I...........? Group: Members Posts: 5,899 Joined: 24-March 06 From: SE PA, near Philly Member No.: 5,765 Region Association: North East States |
both good condition but no trac e of the previous fininsh, what is correct for a -6 ,is there a difference with late car or -4 I'm not aware of any differences between the 4 & six. Front should be a satin finish, with a heavy rubber sqeeze-type seal on the trailing edge. Muffler shield should be painted body color, though the paint would be thin - many were sparayed with rustproofing in the eastern states prior to delivery (along with the rest of the belly). Hope this helps. Pat |
Johny Blackstain |
Jul 28 2007, 08:52 PM
Walnut Elite Stratocaster player Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region |
I'm not aware of any differences between the 4 & six. Front should be a satin finish, with a heavy rubber sqeeze-type seal on the trailing edge. Muffler shield should be painted body color, though the paint would be thin - many were sparayed with rustproofing in the eastern states prior to delivery (along with the rest of the belly). Hope this helps. Pat Pat- grey like primer on mine, w/ spatterings of undercoating. No white to be seen. |
Pat Garvey |
Jul 29 2007, 10:36 AM
I'm not aware of any differences between the 4 & six. Front should be a satin finish, with a heavy rubber sqeeze-type seal on the trailing edge. Muffler shield should be painted body color, though the paint would be thin - many were sparayed with rustproofing in the eastern states prior to delivery (along with the rest of the belly). Hope this helps. Pat Pat- grey like primer on mine, w/ spatterings of undercoating. No white to be seen. Al, I assume you're talking about the muffler cover. I've seen all kinds of variation on these & in all cases, the best body color paint was minimal. Seems like when they painted the underside of the rear trunk, the muffler cover caught some or none of the paint - usually very thin if any, like it not really intended to be sprayed. Pat |
Lo-Fi Version | Time is now: 8th June 2024 - 12:44 PM |
