SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,254 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
last night i went to start up my car, i turned the key (gauge lights come on), i try to start her and everything went dead.
gauge lights went out, no starter, nothing. tried the blinkers, horn etc. nada. so i think the battery might be dead, take a voltmeter to the posts, ~13V. hmmmm ... now what? (IMG:style_emoticons/default/confused24.gif) Andy |
Type 4 Unleashed |
CREATIVE TYPE lV ENGINEERING ![]() ![]() ![]() Group: Retired Members Posts: 787 Joined: 20-June 04 From: Aliso Viejo, ca Member No.: 2,231 Region Association: None ![]() |
Sounds like a connection issue, pull the cables and clean the battery post's and cable ends.
Start at the source, you have voltage, it's just not going any where. |
WaideS |
Has been ![]() ![]() Group: Members Posts: 220 Joined: 25-January 06 From: Valley of the Sun Member No.: 5,475 Region Association: None ![]() |
Sounds like a connection issue, pull the cables and clean the battery post's and cable ends. Start at the source, you have voltage, it's just not going any where. Exactly, you don't have to arch the starter, because if the gauges are out you lost power at the terminals or the ignition switch itself. If you just messed with the switch it probably dropped a ground...... |
Lo-Fi Version | Time is now: 8th July 2025 - 11:33 PM |
