> A little help please, Car not running right
Mikey914
post Aug 2 2007, 12:00 AM
The rubber man
I consider myself somewhat mechanially inclined, but I'm not quite sure what I'm getting into.
The story: My son drives his 1.7 over the pass to Redmond (about 150 miles), car has been runnign great, goes to leave last sunday, gets some gass on the way out. About 4 miles down the road car starts loosing power, sounds like it's not running on all cylinders.
I had my father inlaw drive it over to a local shop that knows little about 914s, and have been told that the engine needs to be rebuilt. I have yet to talk to the shop, but this is the story I've gotten second hand, I'll be calling tomorrow.
My thinking
As it's not smooking, and it's not banging around like a valve dropped, is that it's down to air, fuel or spark
Air- don't think this is an issue as it runs partially
Fuel - could be an injector problem, but my son did mention that it backfires like ther was unburnt fuel in the exhaust, so I'm thinking it's probably spark.
Spark- I was hoping that it was a plug wire grounding out and that the shop would check it, simple fix. It still may be that, or a plug that has broken.
I plan to start the car and pull plug wires until there is no change when I remove one, If it's not the wire (I'm going to replace all) the pull plugs and replace.
This is a stock 1.7, are there any other things I should be on the look out for?
Any feedback is appreciated.
Thanks,
Mark (IMG:style_emoticons/default/biggrin.gif)
Brando
post Aug 5 2007, 04:51 PM
BUY MY SPARE KIDNEY!!!
The retaining wire inside just pushes agains the tubes - it should NOT come in contact with the pushrods themselves.
A broken pushrod... Those don't look to be OEM - stock are aluminum and are the same diameter from the base of the tip to base of the tip - there shouldn't be thinner sections like the ones pictured.
Since you've got the pushrods out, buy a set of Cut-To-Length chromoly pushrods from Jake's store, or get a good used set of stock ones from a member here (post in classifieds).
- Lo-Fi Version Time is now: 1st July 2025 - 04:08 AM
