> Caster settings, Explain please
r_towle
post Aug 12 2007, 01:25 PM
Custom Member
How does the caster setting affect an AutoX car.
What is the best, and why.
Rich
jhadler
post Aug 13 2007, 01:00 PM
Long term tinkerer...
I'm pretty firmly in the camp of caster is good for autox. And more is better. Granted, there's such a thing as too much of a good thing. But the dynamic camber gain more than makes up for the reduced turn-in if that is the ONLY thing you're doing.
But it's all a system. Caster alone is not the end-all-be-all. You need to dial the rest of the car in around it. And a truly hot setup for autox, is not going to be a hot setup for track or street.
Having a lot of caster allows you to run less static negative camber, giving you a better contact patch for braking. Turn-in won't be as light, but the car will have more front end grip when you need it (mid turn). Turn-in then can be played with by toe, or spring rate, or just compensating with the steering nut. I think I'd rather have a little more effort for turn-in if it meant I could carry an extra .15 G around a turn.
-Josh2
- Lo-Fi Version Time is now: 11th July 2025 - 07:09 AM
