r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
How does the caster setting affect an AutoX car.
What is the best, and why. Rich |
jhadler |
Long term tinkerer... ![]() ![]() ![]() Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 ![]() |
I'm pretty firmly in the camp of caster is good for autox. And more is better. Granted, there's such a thing as too much of a good thing. But the dynamic camber gain more than makes up for the reduced turn-in if that is the ONLY thing you're doing.
But it's all a system. Caster alone is not the end-all-be-all. You need to dial the rest of the car in around it. And a truly hot setup for autox, is not going to be a hot setup for track or street. Having a lot of caster allows you to run less static negative camber, giving you a better contact patch for braking. Turn-in won't be as light, but the car will have more front end grip when you need it (mid turn). Turn-in then can be played with by toe, or spring rate, or just compensating with the steering nut. I think I'd rather have a little more effort for turn-in if it meant I could carry an extra .15 G around a turn. -Josh2 |
woobn8r |
Senior Member ![]() ![]() ![]() Group: Members Posts: 607 Joined: 7-January 07 From: Newmarket, Ontario, Canada Member No.: 7,435 Region Association: None ![]() |
I'm pretty firmly in the camp of caster is good for autox. And more is better. Granted, there's such a thing as too much of a good thing. But the dynamic camber gain more than makes up for the reduced turn-in if that is the ONLY thing you're doing. But it's all a system. Caster alone is not the end-all-be-all. You need to dial the rest of the car in around it. And a truly hot setup for autox, is not going to be a hot setup for track or street. Having a lot of caster allows you to run less static negative camber, giving you a better contact patch for braking. Turn-in won't be as light, but the car will have more front end grip when you need it (mid turn). Turn-in then can be played with by toe, or spring rate, or just compensating with the steering nut. I think I'd rather have a little more effort for turn-in if it meant I could carry an extra .15 G around a turn. -Josh2 You had me right up to the point where you say you set up with less negative camber and have more grip in a corner....not in my experience...but I also don't run max caster on my race cars...I do use a pyrometer to maximize all test set ups though....I'm also not sure your more caster/less neg camber theory is correct...but if it works for you...who am I to argue. |
Lo-Fi Version | Time is now: 11th July 2025 - 06:49 AM |
