URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 121,070 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
I can't leave well enough alone. It's 66" wide, 52" from the ground to the top. I cut some masonite supports which will be 1/8" aluminum, and used a piece of cardboard for an end plate. I haven't decided on end plate material, could be CF, FG, lexan, aluminum, whatever.
Attached thumbnail(s) ![]() ![]() |
914forme |
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None ![]() ![]() |
Isn't that tool chest support going to slow you down? (IMG:style_emoticons/default/laugh.gif) I could not resist.
Yeah alpha wood is a little heavier than it might need to be, but for a lot of people it is what they have, and can work with. Sure he could have made a mold and laid them up in CF, or built a buck and mae them out of AL, but for the first attempt I think it will work rather well. Each revision will get nicer, but if it does the job, I don't see the wood being a design flaw. And at 5lbs, I don't think Paul will noitcie the weight difference at all. I do believe he adds weight to make his class minimum. ICBW on that. |
Lo-Fi Version | Time is now: 11th June 2024 - 01:24 AM |
